do i need to use a charcoal cannister?
  • 89325iturbo
    • Mar 2004
    • 723
    Or can ijust put a hose that TB nipple and just let it vent?
    • 34839
    you don't need to but there's no reason not to - it helps fuel economy with no real detriment to performance.
    • 89325iturbo
      • Mar 2004
      • 723
      I have no problem using one. i just dont have the can from my e30 anymore, i must of tossed it.
      • M-technik-3
        • 18946
        I have one, need it. say mail cost from down to you? Came out of a Ti.
        • 89325iturbo
          • Mar 2004
          • 723
          I'll see if I still have mine first. Also there's a check valve in that line with a sensor. I don't have that check valve. Will it do anything if I don't have that plugged in on my engine harness?
            • 34839
            no, it only opens when the ECU grounds it. It's to vent pressure from the fuel tank. the tank can apparently implode from suction.. although mine isn't connected to anything and it hasn't been a problem.
            • 89325iturbo
              • Mar 2004
              • 723
              Ok good. Cause it costs like $75 bucks new.
              • matt
                • 3731
                You may get a code if you don't have the solenoid hooked up.
                  • 34839
                  wonder if an E30 solenoid would work? it's just a 2-pin, ground to open valve.
                  • matt
                    • 3731
                    The ECU needs to see some current flow. I don't think it really cares through what. :)
                    • gregslow318i
                      • Sep 2007
                      • 1918
                      this is true need to have it plugged in
                      looking for a e30m50 swap harness adapter pm me $150 shipped
                      email nitroman12@gmail.com
                      • 89325iturbo
                        • Mar 2004
                        • 723
                        Can I use anything that plugs into the connector. Or does someone happen to have one of these check valves around for sale?
                        • hoveringuy
                          • Dec 2005
                          • 2720
                          It needs to see around .05 amps of flow.
                          Use a 100Ohm, 2 watt power resistor wired in place of the solenoid and it will keep the ECU happy.
                          • RoadHazard
                            • Sep 2007
                            • 163
                            Use no 8 from the diagram below
                            http://www.realoem.com/bmw/showparts...3&fg=15&hl=145
                            90 E30 S50B30
                            http://www.fquick.com/roadhazard/
                              • 37832
                              Just install the canister? I think you'll find a ton of people will sell you one for little to nothing if you post a wanted ad on here.
                              Classic BMW Specialists
                              Grover Beach, CA
                              www.BimmerHeads.com
