Can you bend a valve if...?
  • graphikg
    • Jan 2008
    • 1614
    If you jumped the car by engaging the clutch while it is rolling? I did just that and I started to hear this tick afterwards. I started the car the next day and I still heard the same thing. WTF?
  • u3b3rg33k
    • Jan 2010
    • 2452
    I've done that too many times with no new noises afterward. I don't see how that would bend a valve or cause any other problems unless you did something excessively stupid.
    Ich gehöre nicht zur Baader-Meinhof Gruppe
    Originally posted by Top Gear
    Just imagine waking up and remembering you're Mexican.
    Every time you buy a car with DSC/ESC, Jesus kills a baby seal. With a kitten.
      • 34844
      no, not unless you somehow skipped timing on the chain.
      • JGood
        • Jan 2004
        • 7959
        Exhaust leak? Maybe a small crack opened up slightly during the abrupt jerking around of the engine?
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • graphikg
          • Jan 2008
          • 1614
          ^^^^^ Hmmmm. Well, I am running on just headers right now. I will check if my headers moved around a little.
          • JGood
            • Jan 2004
            • 7959
            You're running open headers, and can hear a tick?
            • Devil Inc
              • Jan 2008
              • 802
              That would be my question.
              • Wh33lhop
                • 11705
                Originally posted by JGood
                You're running open headers, and can hear anything?
                paint sucks
                • u3b3rg33k
                  • Jan 2010
                  • 2452
                  Abrupt jerking as compared to the motion of a running engine?
                  This.
                  • graphikg
                    • Jan 2008
                    • 1614
                    Trust me, I can hear a tick. Its actually pretty loud. I am at work, but I will try to get a sound clip on here so you can hear it for yourselves. I hope it is not a bent valve, but the car is running like sh** and is ticking for sure. I am going to take it to a shop for diagnoses, but got to get my exhaust sys taken care of first.
                    • hoveringuy
                      • Dec 2005
                      • 2744
                      No.
                      The only time I would NEVER jump the car that way is if it involves rain or water.
                      True story: I tried to start my 914 after a heavy rain once and it only cranked briefly before stopping. I thought "WTF?" and considered push starting it for a dead battery until I had the sense to pull a spark plug.
                      Water came out.
                      Water had run down my carbs and filled the cylinders, the engine was hydro-locked. Push starting it would have bown the cylinder heads off.
                      I pulled all the plugs, cranked the water out for a minute, put the plugs back in and drove it to my scheduled brief. Changed the oil that night.
                      VW's!
                        • 34844
                        You can't bend the valve by push starting your car. the only way to do that is if the chain breaks or skips teeth, which is nearly impossible.
                        • JGood
                          • Jan 2004
                          • 7959
                          Yes. The exhaust is mounted solid to the engine, and attached to the chassis. So any hard jolt of the engine could tweak the exhaust and open up a small crack even more. Normal running doesn't involve the same type of hit to the engine as pop starting it does.
                          It's just a slight possibility, a random suggestion. There's not much to 'tap' on an m50... injector, lifter, exhaust, maybe a valve.
                          • u3b3rg33k
                            • Jan 2010
                            • 2452
                            If your engine moves that much, your mounts are shot.
                            • JGood
                              • Jan 2004
                              • 7959
                              Maybe they are. It was a suggestion. Are you done beating it down now?
