s50 no starty
  • spaceshuttle
    • 169
    s50 no starty
    okay tried cranking it and nothing. I don't hear the buzz of the ICV or the pump going on maybe that's just me though. Its not getting spark or fuel tried to jump fuel relay still got nothing. I also don't have a CEL on. I have a 413 ecu with the stock chip still in it. Anyone have any thoughts? How do I check pins on the harness adapter?
  • M-technik-3
    • 18946
    What chassis? Who's adapter? was it made for this car or a blanket batch of cars. Do you have voltage at the Ecu? There has been NUMEROUS 24V non starts and the same questions are asked each time. Please review some of the last few no start threads.
    • SamE30e
      • Sep 2007
      • 4319
      Did you hook the relays up properly. The wires coming off the harness that goto the battery junction, one of them is ground. Also, is the engine grounded?
      1985 325e 2.8 Turbo VEMS
      • spaceshuttle
        • 169
        its a 89 325i. The adapter was made from someone on here. I checked other threads and I've checked common things like plugs and fuel lines everything is connected up right. Relays are correct and they are grounded, so is the engine.
        How do I check if the ecu is getting power?
        And also after cranking the engine I can hear the evap valve and it sounds like air is coming out of it is this normal?
        • e46s54dr
          • May 2008
          • 1059
          From what Ive been reading, I believe you need either a silver 506 or a aftermarket chip if using a 413 for an s50b30us engine. But I think it should run even with a stock red label 413, maybe a little rough?
          • e46s54dr
            • May 2008
            • 1059
            It's not a silver label 413 dme is it? Most of the silver ones have the ews immobilizing system worked into them which will cause you to not get spark or fuel as stated.
            • gregslow318i
              • Sep 2007
              • 1918
              I made the adapter and it was tested and worked. are you sure you have the power/gound cables connected correctly? dead battery? know good dme?
              looking for a e30m50 swap harness adapter pm me $150 shipped
              email nitroman12@gmail.com
              • spaceshuttle
                • 169
                I have a red label 413. I am pretty sure I have things connected right I have the ground on the passenger side and the one from the engine is also grounded on the same side. The fuse box is getting power. And it cranks really good so the starter is all hooked up good.
                So it should be the DME? Is there a way to tested without having to find a new one?
                • nrubenstein
                  • 3148
                  Are you sure there is both no spark and no fuel?
                  2002 BMW M3 Alpinweiß/Black
                  1999 323i GTS2 Alpinweiß
                  1995 M3 Dakargelb/Black
                  - S50B32/S6S420G/3.91
                  1990 325is Brilliantrot/Tan
                  1989 M3 Alpinweiß/Black
                  • M-technik-3
                    • 18946
                    You said in the first post, "okay tried cranking it and nothing." That to me means the engine doesn't not turn over at all, nor did you get a relay noise or a fuel pump.
                    Now it's turning over? What did you change or did you fail to convey the engine was turning over?
                    • gregslow318i
                      • Sep 2007
                      • 1918
                      pic of said ground and battery + connection
                      • spaceshuttle
                        • 169
                        Sorry I should of wrote that better it cranks good just wont turn over at all.
                        And yes I am positive there's no spark or fuel
                        Ground to the engine
                        Ground from the engine haress
                        the two cords in my hand go to the fuse box
                        • 325islovE
                          • Feb 2007
                          • 133
                          ^looks like youre missing a power wire for the dme, check that big bundle of wires heading to the dme
                          1988 325is alpine
                          1989 325is zinno RIP
                          1992 325ic alpine
                          1986 325e cirrusblau
                          • gregslow318i
                            • Sep 2007
                            • 1918
                            off topic but what trans/flywheel and starter are you using?
                            • M-technik-3
                              • 18946
                              No it's not, because by his definition the starter was cranking but the engine was not turning over.
                              And if the crank doesn't turn then of course you gonna not get fuel nor spark.
