s50 no starty
  • StereoInstaller1
    GAS
    • 22679
    There is a HUGE O ring right where the body meets the engine. If you get it misaligned it will fail and it will all blow up.
    Closing SOON!
    Thanks for 10 years of fun!
    • spaceshuttle
      • 169
      Does anyone else know if I am missing a cord to the DME I don't see anything unless the cord is in the plug part of the harness which is under the manifold. I am using a g260/ e36 flywheel and e36 starter
      • gregslow318i
        • Sep 2007
        • 1918
        can I get a pic of the dme....
        also does the check eng light come on when you turn the key on?
        looking for a e30m50 swap harness adapter pm me $150 shipped
        email nitroman12@gmail.com
        • spaceshuttle
          • 169
          And I don't have a check engine light coming on at all
          • 99em1
            • Dec 2009
            • 200
            No CEL in any key positions?
            • spaceshuttle
              • 169
              yes doesn't come on in any positions
              • gregslow318i
                • Sep 2007
                • 1918
                that would indicate that the dme is not getting power, check your main power relay (white one, 5 terminal one)
                • spaceshuttle
                  • 169
                  Okay made a jumper and checked it still nothing. Maybe I have a bad DME?
                  • spaceshuttle
                    • 169
                    Does anyone know or think that's what it is?
                    • hoveringuy
                      • Dec 2005
                      • 2748
                      What did you jumper?
                      I honestly have forgotten if the main relay gets the "on" signal from the DME or if it gets power from the ignition, which energizes the DME.
                      • spaceshuttle
                        • 169
                        The main white relay
                        • gregslow318i
                          • Sep 2007
                          • 1918
                          yes but how did you jumper it? did the relay click when you ground the brown wire. or did you run 12V+ power to the red/white wires(2total)
                          • spaceshuttle
                            • 169
                            I put a bent paper clip in the 85 and 86 slots and yes I can hear it click when I did that
                            • spaceshuttle
                              • 169
                              tried a new working ecu and still no CEL light in any position and doesnt turn over. Does anyone have a picture of the actual cord that powers the ECU and the Ground to it?
                              • e30s50dan
                                • Nov 2008
                                • 2076
                                Which wiring harness is it from. E36 or E34? That may help on finding the dme hottie
                                NASA
                                BMWCCA member
                                PCA member 25yrs
                                1991 318IS slick top
                                1997 M3 sedan
                                2001 325CI DD
                                “whoever turns the wheel the least, wins"
