Tubular Front Sub frame and Custom Pan for dual pump set up
  • Teaguer
    • Sep 2004
    • 6167
    #31
    Originally posted by rpm620
    i would love to have a subframe to fit an E36 Pan.
    This would fit the e36 pan. Not sure if the e36 pan would still need to be clearanced on the back side though.
    Would be easy enough to test once this is mounted on a car with the S54 installed.
    So once the reinforcing is done to the mounting are of the subframe will a stock anti-roll bar be able to fit on the front side of the subframe?
    • surebimmer
      • Jan 2004
      • 978
      #32
      Does the tubular front sub frame weigh less then a standard sub frame. Do euro headers clear this sub frame. And with moving the sway bar to the front does this change effectiveness of the bar?
      • Lag
        • Jul 2008
        • 358
        #33
        I am not sure about the standard sway bar, but the m3 bar bolts up with adjustable end links. I imagine the same would go for the regular e30.
        • Lag
          • Jul 2008
          • 358
          #34
          I have a feeling that this may weigh slightly more than the stock sub frame, I am willing to bet the euro headers would fit just fine based on where people have had to notch the stock sub frame, and I do not think moving the bar will effect anything. I believe the e36/46 cars have them in front.
          Sam
          • TinyT
            • Jan 2011
            • 152
            #35
            the bar will work the same way mounted in the front. the tubing is .120 wall dom and with the reinforcing plates, etc. it weighs more. I will weigh them out when I do the next one.
            • surebimmer
              • Jan 2004
              • 978
              #36
              Will you be willing to sell just the sub frame? Like the idea of the sway bar in the front, won't get in the way of the header. A E34 pan would still clear this?
              • TinyT
                • Jan 2011
                • 152
                #37
                Yes I am more than willing to sell just the subframes too.
                • Lag
                  • Jul 2008
                  • 358
                  #38
                  The E34 pan will fit this sub frame with the sway bar in the back, but I do not think that the sway bar in the front. From what I remember the e34 pan sits pretty close to the steering rack and there is not much room in between.
                  Sam
                  • surebimmer
                    • Jan 2004
                    • 978
                    #39
                    Sam
                    Ya after I posted that I thought of the front sump being in the way, for the front sway bar. Thinking about a S54 down the line and might want to pick one of these up.
                    • Lag
                      • Jul 2008
                      • 358
                      #40
                      Well we could put swaybar mounts on the front and back so you are future proofed, no big deal.
                      Sam
                      • ForceBangBlow
                        • Jun 2008
                        • 61
                        #41
                        Hey guys, just thought I'd chime in with a pic with the finished coated product. Can't wait to see how it looks on the car! :up:
                        Jake Rawson - Media blasting * Powder coating * Fabrication * Service * Repair
                        • bataangpinoy
                          • Jul 2008
                          • 1636
                          #42
                          so what is the cost of having a subframe modified or purchasing just a subframe?
                          if we can run rear sump e36 pans on any of the m5x/s50-s52 i am more than willing to buy one.
                          My feedback:
                          http://www.r3vlimited.com/board/showthread.php?t=186328
                          http://e30tech.com/forum/showthread.php?t=74911
                          Instagram:
                          @gears_n_glory
                          @functionmotorsports
                          • TinyT
                            • Jan 2011
                            • 152
                            #43
                            $450 if you send me yours. I will coat it and ship it back to you.
                            modified, and reinforced.
                            If you dont need it coated, $375
                            • rThor432
                              • Feb 2007
                              • 3907
                              #44
                              That looks like very nice work. The alu welding is impressive. Out of curiosity, what does the pan modification increase the oil capacity to?
                              • TinyT
                                • Jan 2011
                                • 152
                                #45
                                thank you! I figured out how to weld the cast better as I went on so future pans will come out even better ;)
                                I will check with sam tomorrow on what the pan came out to as far as capacity. I believe he has the numbers.
