Tubular Front Sub frame and Custom Pan for dual pump set up
  • TinyT
    • Jan 2011
    • 152
    #46
    Hey guys, sorry for no updates on this. I still have to figure out the total oil capacity and get some pictures of it bolted up to the motor and in a car!
    • Lag
      • Jul 2008
      • 358
      #47
      Hello all,
      I apologize for the delay in getting some up-to-date pics. I got around to bolting it all up to the motor on the engine stand (car is at the body shop) so you can get an idea of how it all works together.
      Overall the oil pan capacity went up slightly. It holds about 32.5 more cubic inches or .53 liters. So not a significant increase, but pretty good for removing such a large portion of the factory sump.
      Sam
      • FredK
        • 14763
        #48
        Whew, your headers look GREAT!
        • Lag
          • Jul 2008
          • 358
          #49
          Why thank you! :)
          • E30Strube
            • Jul 2008
            • 181
            #50
            I'm looking to start my S54 swap soon and this could come in handy. How much more clearance do you get by going with this subframe/pan combo over the E43 pan? You mentioned removing the rear sump for the S54 and going with something else. What sump do you use?
            • Teaguer
              • Sep 2004
              • 6167
              #51
              More clearance with what?
              Basically you can't run a rear sump pan unless you notch into your firewall or you hack up your subframe.
              The front part of the rear sump pan is shaved down or back and there is additional capacity added to the sides of the existing sump.
              • E30Strube
                • Jul 2008
                • 181
                #52
                I meant E34 pan in my original post. It was mentioned a couple times in this thread that this new subframe/pan combo would address the issue of how low the E34 pan sits when mounted. So how much more clearance do you gain?
                • rThor432
                  • Feb 2007
                  • 3907
                  #53
                  It's a bummer that I just sold the pump/pan from the S54 that I'm putting in the M3. I've gotta pick one of these up when I get the engine for my other E30.
                  The work all looks great! Keep it up!
                  • TinyT
                    • Jan 2011
                    • 152
                    #54
                    Thanks guys! Im ready whenever anyone is to do these so just let me or sam(Lag) know.
                    • BeirBrennerE30
                      • 2740
                      #55
                      subscribed so I can find this later. Can anyone confirm that the s54 headers clear the modded subframe?
                      e30sport.net
                      '06 M3 Competition - 6-speed
                      '97 Range Rover Vitesse
                      • Mr. Horsepower
                        • 386
                        #56
                        This looks interesting, but I would say it is a very very much more difficult way to do it compared to how mine is done. I assume you have seen the pics since you used one of them above here.
                        When that is said, how is the weight on the sub frame you are making compared to the stock one?
                        Also, there would be a benefit to have sway bar mounts both front and rear. So if you are going to put in an E30 engine later, you will not have to change the sub frame.
                        1987 BMW E30 M3 RB26
                        2016 VW Polo 1.2 TSI R-Line
                        Originally posted by 5spoke
                        Fucking norway and your sick clean ass e30's! Yes i am yelling!
                        • TinyT
                          • Jan 2011
                          • 152
                          #57
                          How so? this way the subframe is all reinforced and much stronger than the factories, and when the pan is notched and sumped it provides more capacity and plenty of clearance. We're happy with this way
                          • A.J.
                            • 95
                            #58
                            Still very interested! Is the front swaybar mounting just a mirror image of the rear mounting (bar turned 180 degrees)? You mentioned adjustable swaybar links; do you use M3 style links that mount to the strut carrier?
                            • Lag
                              • Jul 2008
                              • 358
                              #59
                              I THINK you the new clearance is a couple of inches but I am not sure. Basically the E34 pan hangs well below the subframe and with this set up the sump is about .5" higher than the subframe. I would also be willing to bet the overall thickness of this subframe is less than the stock unit resulting in more clearance.
                              I have not tried any other headers on this set up but this subframe is smaller dimensionally especially where the headers pass through. I would think, based on the minimal amount the factory frames have to be modified, that the stock headers (euro s50 or s54) would clear this. If someone sent me a pair I could test fit them. I do not have any stock headers laying around.
                              Yes, you could mound the sway bar 180 degrees around and it would bolt up the same way. My car is an M3 so I am using adjustable end links and they will work fine. Do they make adjustable end links for non-M cars? If so they should work as well. The sway bar placement is not too far from stock and that's why adjustable units would be best.
                              Sam
                              • craz azn
                                • 749
                                #60
                                Gorgeous headers. Where did you source those? Cost? Looks kinda like Kromerkrafts... do want. :)
                                Rippin' Proper | Youtube | Vimeo |
