The comprehensive Air Conditioning thread.
  • 416stroker
    • May 2008
    • 2448
    Danny
    I paid 200 for mine at western tube and hoses.
    84 318I Delphin RIP
    87 325IS delphin 24v Sold
    89 325 Alpineweiss
    • Danny
      • 14217
      Originally posted by 416stroker
      Danny
      Did they install them? Charge your system? Or just build the hoses?
      • blackhawkimpact
        • 2415
        My local shop wants $220 for custom lines, install, and system recharged. Just haven't had the time to take it to the shop.
        Also, you can buy custom AC lines from Zionsvilleauto for $249
        • Supadave
          • 1006
          do these work with m42 cars? I know there are a lil different.
          https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
          • nrubenstein
            • 3148
            Originally posted by Danny
            When you used the ray's blocks, did you use e36 or e30 lines? Or did you have to weld one of the fittings like a few posts in the thread above say?
            E30 lines, no welding, no fiddling. If you had the Seiko Seiki R134a retrofit compressor, those lines will not work.
            2002 BMW M3 Alpinweiß/Black
            1999 323i GTS2 Alpinweiß
            1995 M3 Dakargelb/Black
            - S50B32/S6S420G/3.91
            1990 325is Brilliantrot/Tan
            1989 M3 Alpinweiß/Black
            • StereoInstaller1
              GAS
              • 22679
              THAT is good to know, thanks.
              Can we get a link to the blocks too? Anyone?
              Closing SOON!
              Thanks for 10 years of fun!
              • dude8383
                • Jan 2005
                • 10387
                Luke, check out the e30tech link at the top!
                • StereoInstaller1
                  GAS
                  • 22679
                  Aack, do I have to?
                  Closing SOON!
                  • 416stroker
                    • May 2008
                    • 2448
                    They built them installed them. I think they vacuumed my system. But I took it all apart after to install the good pump and all the new r134 shit
                    84 318I Delphin RIP
                    89 325 Alpineweiss
                    • herlsy
                      • Sep 2009
                      • 339
                      Sooooo....is anyone going to get into which refrigerant they used with the m50 compressors?
                      I've got lines sorted, i don't think my car was ever converted to r134a. Anyone know if it would be ok to run freeze12 through the m50 compressor?
                      • Overlord475
                        • Dec 2010
                        • 799
                        What is the weight capacity of R134a needed for the S50 Denso 10PA17C compressor combined with E30 components? (i.e. E30 condenser, expansion valve, dryer, evaporator, etc.)
                        I was thinking 1000g or 36 oz? Approx 3 cans
                        And what oil viscosity did you guys use? 46???
                        --->>>1988 SETA 2.7i Build Thread (Turbo Prep)<<<---
                        • Wishno87
                          • 6025
                          Anyone know anything about wiring for the compressor and such? Idle bump for the ECU etc?
                          • Supadave
                            • 1006
                            ^^^ this please
                            • dude8383
                              • Jan 2005
                              • 10387
                              Nothing on the idle bump huh guys?
                              • nrubenstein
                                • 3148
                                I just plugged it in. No changes needed. As for the idle bump, I can tell you that the info is on this forum because I found it, but I can't recall the location.
                                My recommendation is to run a wire out to the harness connector, though, as this avoids the risk of hacking up the harness.
