what should I do to rev a m50 to 10k
  • ogbimmer
    • Jul 2010
    • 936
    I figure since I built the whole m50 for turbo as a 2.5 I should built the top end to rev to say 10k. What do I need to change/ get. new valves, springs, and retainers? anything else? Has anyone been to the land of 10k in a m50?
    " WHY DO YOU NEED 300HP TO DO THE SPEED LIMIT?"
  • JGood
    • Jan 2004
    • 7959
    If you spin an m50 to 10k you'll probably send a piston to the moon.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • xwill112x
      • Jan 2009
      • 4236
      you're gonna need a rb20 for that kinda revving lol
      • LittleItaly
        • Jul 2011
        • 21
        really? so even with a hardened crank and harden pistons. its still not happening?
        "fashion is not something that exists in dresses only. fashion is in the sky, in the street, fashion has to do with ideas, the way we live, what is happening."
        -- COCO CHANEL
          From what I've read in some track forums, the first thing to do would be to get a spare engine or two. The head isn't too hard to improve, but the bottom end likes to come apart when run significantly higher than the stock rev limit.
          • bimmerteck
            • 762
            Save the money you would spend on this towards an s54 swap for your M3. You can thank me later should it ever crawl out of "basketcase" status and be up for sale.
            • mr2peak
              • 2388
              Why does the bottom end like to come apart? The stroke is actually pretty short, shorter than a toyota 4age and that engine can rev pretty good
              Drive it hard. Maintain it well.
              A Topless Memorandum
              • bimmerteck
                • 762
                There's a lot more than just stroke that comes into play when attempting to run a motor at 10k rpm. The biggest hurdle is the weight of the rotating assembly in which the m50 is much heavier than the 4age. (it has 2 extra cylinders worth of pistons and rods for instance ;) )
                • e30s50dan
                  • Nov 2008
                  • 2076
                  Not to mention the timing CHAIN spinning to 10k. Damn"!!
                  NASA
                  BMWCCA member
                  PCA member 25yrs
                  1991 318IS slick top
                  1997 M3 sedan
                  2001 325CI DD
                  “whoever turns the wheel the least, wins"
                  • bmwstephen
                    • 2463
                    smelt the engine and rebuild it as a ferrari engine hohoho
                    • Myster-E
                      Performance
                      • 552
                      Just shift from third to second at rev limiter you'll get to 10k
                      1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
                      Visit www.BimmerHeads.com for all of your 12 valve needs!
                      • LJ851
                        • 7919
                        How many times do you want to rev to 10k?
                        Lorin
                        The M30 is God's engine.
                        • Farbin Kaiber
                          Lil' Puppet
                          • 29502
                          Full body armor.
                          • ed94r
                            • Mar 2004
                            • 382
                            You should imagine what could be plausible in a M/S50 longblock, realize you were asking a purely rhetorical question and not at all prepared for the $20K bill, and stick to a K20.
                            Ed
                            1988 E30/S50...now with S52; Track
                            1994 Miata R; ES Solo2
                            1998 Lexus LX470; Wife (Slee'd anyway)
                            2002 BMW 530i; A+ Commuter
                            2002 BMW 325iT; Sport/Premium 5-speed
                            2011 21' EconoTrailer
                            • DTM190
                              • Nov 2008
                              • 1107
                              Full body armor.
                              lulz, qft
                              qft2
                              Originally posted by der affe
                              first try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
                              if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
