24v stroker?
  • Luis325
    • 3847
    24v stroker?
    Hey guys just wanted to know if anyone here has done a similar stroker and what opinions do you have and what type of gain/numbers can i expect? Im planing on building this or something similar for my vert next year...
    Starting with a 1995 M50 Vanos block with a S50 3.0 crank and rods, and M50 Vanos Pistons with notched valve reliefs and notched skirts, M50 Head with S50 cams and springs. Ebay short tube headers to a 2.25 double exhaust with borla [COLOR=blue !important][COLOR=blue !important]muffler[/COLOR][/COLOR] (no cat, no resonator) M50 Intake manifold, OBD1
    413 ECU with Turner Chip, Euro Maf, Lightweight Flywheel.
    Thanks
    1986 "C2 2.7 Alpina" Sedan
    1987 325ic Black Vert
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    Sounds like you have the equivlent of a 2.9l stroker.. I think? I would expect ~stock S50 numbers maybe a little more.
    Honestly, I would have sourced some M54B30 pistons and built an all stroke 3.0l.
    • ZM Blue Devil
      • Dec 2006
      • 13836
      get a s52.
      Levent
      %20levent@gutenparts.com
      Ladies:
      • e30rapidic
        • 2167
        so that will be about a 2925cc?? So 90-95% of S50 power plus the mods of about 30hp???
        240-250hp maybe?
        '87 325ic, powered by S50.
        • RobertK
          • Jun 2005
          • 5864
          240-250hp maybe?
          Sounds about right to me.
            • 34844
            I'd just buy an S52 and call it a day. you might reach the same peak HP, but it won't have the same torque.
            • trackjunkie21
              • Jan 2010
              • 3962
              Or get m54 internals, Bore stays the same but the stroke is greatly increased.
              Originally posted by Wh33lhop
              VANOS: sometimes you just need to go full retard.
              • dude8383
                • Jan 2005
                • 10387
                almost did this with my m50 block. would have been a sweet stroker.
                my 2.8l franken motor comprised of:
                m52 crank, rods, pistons
                s50 cams
                16lb flywheel
                stock injectors
                stock maf
                3 angle on the head
                ported the intake chambers and exhaust manifolds
                made 205 whp and 182lb ft of torxxx
                expect to make somewhere around that number.
                • MrSlacker
                  • 2494
                  s50 cams
                  16lb flywheel
                  stock injectors
                  stock maf
                  3 angle on the head
                  Except then it blew up and you swapped an S52 like you should have done from the beginning. I drove dude8383's stroked M50 and S52 - you can definitely feel the difference so just go with S52 right away.
                  My Seller/Buyer Feedback
                  Performance Aftermarket Parts & Accessories
                  • brokenbimmer533
                    • 317
                    I did something similar to my m50NV
                    S52 crank
                    135mm Integrated Engineering Rods
                    8.5 cr wiseco pistons 84.5mm bore
                    oringed block and MLS head gasket
                    3 angle valve job
                    all new stock parts after that
                    Running megasquirt ems
                    3.0L if my math is correct.
                    • slow95tsi
                      • Aug 2009
                      • 131
                      Im in the process of doing the
                      M50tu block
                      M52b28 crank and rods
                      M50tu pistons
                      .027 head gasket
                      S52 cams and trays
                      To make a high compression obd1 2.8
                      Still gathering parts now
                      But everyone that keeps saying buy a s5x doesn't realize we will be making very close to s5x power for ALOT less money
                      • Adrian_Visser
                        • Jun 2006
                        • 2823
                        How much are you into it for as of this moment?
                        I paid $1600 for my s52, albeit it isn't freshly overhauled I don't think you'll be under that on your build. Add to your bill a tune specifically for your motor and I can't see you being under $2500.
                        '89 Alpine S52 with goodies
                        • Tchao
                          • Apr 2007
                          • 223
                          I plan on buying a M50 for $300.
                          S50 crank for $200
                          S50 cams (Free, but lets say $150)
                          S50 rods (lets say $40)
                          CP Pistons 84.5mm ($900)
                          Machining $500
                          Tuning is free (but assume EMS to over do it....VEMS $800)
                          ~$2100 before EMS.
                          OR $2900 for a fairly built turbo ready BRAND NEW "S50 2.9L" seems a whole lot better then $2000 for a 140K miles who knows whats it been though real S50....just saying.
                          • FredK
                            • 14762
                            But to be BRAND NEW you'd need:
                            Main bearings $100
                            Rod bearings $50
                            Rod bolts $60
                            HG kit $150
                            Lower gasket set $60
                            Timing rails $50
                            Timing chains $60
                            Timing chain tensioner $80
                            Timing chain tensioner upper $60
                            Head bolts $20
                            $720
                            It is definitely better to have a zero mile engine than to have a 140K mile "who knows what" engine, but it definitely costs more than the cost of the rotating assembly to build up a new engine.
                            • Robotin
                              • Jun 2011
                              • 4471
                              ive heard of people taking m50 blocks and putting s52 shit in it..
                              but thats all i know...
                              1989 325i SETA stroker [delphin] R3V'd 8/31/2011
                              1989 325ix [zinnoberrot] $OLD
                              1970 2002 [Nevada]
                              Originally posted by Herr Faust Schinken
                              guy must have slid into something that doesn't look like a car vs car hit
                              Originally posted by ak-
                              Must of slid into Rob
