It is possible?: Modified front subframe to run stock E36 oil pan
reuse E36 gear
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
Look on the track section. There are a billion threads on it there.
What makes it impossible to use a standard pan? I'll confess that I don't quite understand why you would not be ale to cut it down.2006 GMC Sierra 2500HD 4WD LBZ/Allison
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpicComment
here you go:
Bimmerforums is the preferred online BMW Forum and community for BMW owners. At Bimmerforums, you will find technical how-to information maintenance specifics audio advice wheel and tire combinations and model specific details not found anywhere else. Our professionals are here to help make sure you find the answers you need to your questions and our community is here to help other brainstorm ideas for the future.Comment
Amazing! Thanks so much!Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
Iv never done one, would anything interfere with where I notch and add a sump?Comment
From the estimation I made it seemed really close to where the pickup would end up but im not exactly sure. Could I just send it to you to check it out? Like I said before if it actually does indeed work this would be a much better way to go rather than chopping up an e34 pan and shrinking the capacity even more. I think a lot of people would be interested in this route.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
Just measure back an inch and a quarter from the front face of the sump, that is how much I take out. I have no way of checking what will work, Iv never even owned a bmw :) I just got the job for the s54 pan, figured out what works, and started modding those. If you can decide where exactly the pickup goes and then just measure 1.25" back from that front part of the sump, that is where the new wall would be.Comment
Just start chopping the s52 normal pan; I'm sure sombody will give you one locally to chop up for test. If you were local to me I'd hand you one :DJust measure back an inch and a quarter from the front face of the sump, that is how much I take out. I have no way of checking what will work, Iv never even owned a bmw :) I just got the job for the s54 pan, figured out what works, and started modding those. If you can decide where exactly the pickup goes and then just measure 1.25" back from that front part of the sump, that is where the new wall would be.
Shouldn't make any difference to design/fab style.
not needed to be chopping up perfectly good S54 pans that can be ran as is in many track cars when doing the same to a pedestrian s52 pan would be more efficient. Also could consider adding more pickups to a s52 oil pan (modified) so a S54 oil pump setup with 3 pick ups could be ran with the normal S52 pan.
I think people would be happier to buy a NEW S54 oil pump and pay T-t for a multi-pick up s52 pan vs spending extra ++ to cut up a much more valuable s54 oil pan.OBD1 M54/M52TU swap as a M50b25
Ill cut anything up :) I just need to know where the pickups go or what has to happen to make this work. I don't own a bmw or really know how each oiling system on them works, I'm just doing the fabrication and trying to educate myself!
Does anyone have a picture of where the pickup tube is inside an s52 pan? I need to know if my 1.25" clearance is going to hit it in stock form and if so where I would need to mod the pickup.Comment
