CAlifornia BAR/SMOG/engine swap thread.
  • Sean S.
    • Aug 2012
    • 196
    #91
    You're not that far from me. What say we meet up some afternoon? I'd love to see your car. Lunch and beer on me, of course.
    Sean
    • clavinZERO
      Hella sick E30
      • Mar 2004
      • 2027
      #92
      Woot!
      "BMW Style 32 Poster-Child"
      HTTP://WWW.CLAVINZERO.COM/e30-5-lug
      **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
      • arch4ngel
        • Dec 2008
        • 791
        #93
        Read the build thread in my sig, all the info is in there.
        You need to use all the emissions equipment, plumbing exhaust etc. from an obd2 e36.
        Project
        Feedback
        • 2mAn
          Señior Mod
          • 21075
          #94
          ***cross post from my cars thread***
          Well, I still didnt pass but the new Magnaflow cat made a HUGE difference. NOx are not an issue anymore, now its just figuring out the HC issue. Im starting to wonder if replacing the coils will help because it seems like its not burning the mixture enough, or theres still just too much fuel.<br />
          <br />
          Im also wondering if the thermostat might not be the right one (though I think we stuck with the original OEM temp) and its not letting the car get truly hot enough.
          Still not a victory, but we are making good solid progress, which is more than what I can say about the previous times I went to the ref.
          Simon
          Current Cars:
          -1966 Blue Boat
          -1969 Red VW
          -1986 White BMW
          -2006 Green Thing
          Make R3V Great Again -2020
          • 2mAn
            Señior Mod
            • 21075
            #95
            bump... any ideas ????
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            • earthwormjim
              • Jul 2014
              • 434
              #96
              Are your O2 sensors fairly new?
              Your engine is pretty far from stock, what tune are you using? Maybe too rich?
              Normally if it was just from your cats not being hot enough, you'd still pass the 25mph test. But you failed both tests...
              • 2mAn
                Señior Mod
                • 21075
                #97
                Its OBD1 so theres just one, and its now ~10months old. Its a new Bosch unit that I installed right before I started this fun process
                Its really not that different from stock. The only aftermarket part is the tune. I am kinda wishing I had gotten a WAR chip because then I couldve gotten this tuned directly to the car, but listening to members here over my mechanic lead me to a TRM chip thats tuned for my setup. They've been helpful and sent me another chip, Im in contact with them now to see if they can make a few more adjustments to get me in the sweet spot.
                Im wondering if I shouldve some more miles on the new cat, because it had ~ 40 miles on it... again, another recommendation here was to get the new cat and go straight to the ref. Even he said, that I shouldve driven it a little more, but Im clueless to this stuff.
                Is there anything ignition related that could help? Does the cat need more miles? The car was at rest again for a while, but he did go through the 15mph test, then he stopped and let it reset the clock and tested it again at 15mph
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • earthwormjim
                  • Jul 2014
                  • 434
                  #98
                  Your car is being tested as an M50? The cat your using is for an M50? I wonder if maybe the cat you're using isn't enough for your larger, higher output engine.
                  Is there a difference between an S50B30US cat and an M50B25 cat? The whole exhaust has a different part number, but I wonder if the cats themselves are different. Both engines I know have the same smog limits.
                  • 2mAn
                    Señior Mod
                    • 21075
                    #99
                    I thought the Magnaflow parts were the same, but I looked it up and the S50 is individual cats while the M50 is a dual in and out
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    • 328ijunkie
                      • May 2007
                      • 3961
                      #100
                      too rich :P
                      Check Us out on Facebook
                      Full Product Line Tuning
                      • 2mAn
                        Señior Mod
                        • 21075
                        #101
                        Originally posted by 328ijunkie
                        too rich :P
                        haha yes, definitely yes. but is it all in the tune?
                        any other way to fix this? is there any possibility that my old igntion coils need to be replaced??
                        ps. Ive really been considering going to OBD2 once this is all done, but thats a lot of work for what is probably a little gain
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        • 328ijunkie
                          • May 2007
                          • 3961
                          #102
                          Hard to say conclusively, thus why OBD1 sucks. No data feedback. could be plugs/coils/vac leak/exhaust leak before O2, etc...
                          • 2mAn
                            Señior Mod
                            • 21075
                            #103
                            Ok, stupid, basic question... Lets ignore the possibility of leaks, what can I test/ check on the the ignition related stuff to make sure they are proper and correct?
                            Simon
                            Current Cars:
                            -1966 Blue Boat
                            -1969 Red VW
                            -1986 White BMW
                            -2006 Green Thing
                            • 328ijunkie
                              • May 2007
                              • 3961
                              #104
                              Not alot you can do to test it other than some resistance tests which ive found to not always be correct (like OBD1 crank sensor, can be dead but ohm out fine)
                              • 2mAn
                                Señior Mod
                                • 21075
                                #105
                                I've been trying to wrap my head around this because it really is feeling like an ignition issue. I plan to replace the Coils simply because they are old and suspicious, but Im thinking I should change the plugs at the same time. Is there a "hotter" plug that could help this issue?
                                Simon
                                Current Cars:
                                -1966 Blue Boat
                                -1969 Red VW
                                -1986 White BMW
                                -2006 Green Thing
