Originally posted by mtech325
View Post
CAlifornia BAR/SMOG/engine swap thread.
Originally posted by Sean S. View PostWell, technically, I passed ... But even after supplying the title to the donor car and showing the inspector that the VINs all match, I still have to go get a letter from a BMW dealership stating that the ECU has not been altered.
So close, but no BAR sticker!
Sent from my SM-G960U using Tapatalk
They don't need the VIN from the donor car, I was just hopeful that they would be able to run the donor car vin and see that it was originally sold in CA and thus was originally compliant with CA emissions. No such luck so I had to go to a dealership and have them write how the ECU was not modified and was a California compliant car. $200 later, I had this:Sent from my SM-G960U using Tapatalk
Where are you? I had a good experience with the inspector at Las Positas College in Livermore. It's really all a matter of if you are trying to get one over on them, or if you are honest and sincerely trying to get everything right and legal. If they want to, any inspector can make your life hell, don't give them a reason to and they won't Sent from my SM-G960U using Tapatalk
hello, i will be embarcing to go bar legal in my 87 e30 with a obd2 m52. im curious as to what i should expect going forward. I got the exhaust and air pump already, im working on ews delete. i am using to what i believe to be a modified m50 fuel rail? so that the fuel regulater is on the rail itself where as e36 regulater is on the chassis. now i know the e30 charcoal canister works for m52 but will that hurt me in getting it passed?
anything is helpful, thanks.
Originally posted by Sean S. View PostWhere are you? I had a good experience with the inspector at Las Positas College in Livermore. It's really all a matter of if you are trying to get one over on them, or if you are honest and sincerely trying to get everything right and legal. If they want to, any inspector can make your life hell, don't give them a reason to and they won't Sent from my SM-G960U using Tapatalk
Originally posted by robby41 View Posthello, i will be embarcing to go bar legal in my 87 e30 with a obd2 m52. im curious as to what i should expect going forward. I got the exhaust and air pump already, im working on ews delete. i am using to what i believe to be a modified m50 fuel rail? so that the fuel regulater is on the rail itself where as e36 regulater is on the chassis. now i know the e30 charcoal canister works for m52 but will that hurt me in getting it passed?
Originally posted by e30strokr View Postsomething that I found out for OBD1 to use a Magnaflow CAT converter #332008 dual in-out OE D-193-117 for $200, not bad.. got everything ready but its easter weekend so next week for the swap!!
Wanted to share, I did finally get my Dinan SC / S50B30US BAR'd. It took 4 appointments. The final 2 appointments were to get a mechanic to come to the appointment with me, bringing a scanner that could read an E36 speed sensor. Apparently the scan tools the guys have at both Fullerton and El Camino (Torrance-ish) have a known issue reading E36 Speed sensors from the diff via the diag connector. So I had to meet a guy up here in El Camino, have that BAR referee tell me he spoke to the other ref and knows he cleared my car, but since he didn't verify the V2 supercharger that doesn't match the Dinan EO for the kit (the EO says V1S), that's considered a fail, when the literally only difference is angle cut gears rather than straight ones to cut down on the noise with the ratios and pulleys untouched.
Was an incredible pain in the ass. Car needs to be running absolutely perfectly, no excessively high idle, vacuum leaks, or non working catalytic converters (Magnaflows typically need to be replaced every two years when you smog).
If I had to do it all over again in 2021+, I'd probably just electric motor swap it and call it a day :D
Peter
Originally posted by peterdawolf View Post
If you're doing a 1995 S50B30US, that $200 catalytic converter *WILL* fail your BAR inspection. That cat applied to the 1992-1995 M50 cars, but the S50B30US has two individual cats, one on each pipe, with the same otherwise mid-section configuration (both fit the mid section). I know this because I got turned away until I went back and had the $300 a piece 2 single cats installed by the same Magnaflow dealer a month later and then back for another inspection.
sounds like the shop messed up your catalytic order? plus all magnaflows are not available at the moment
BTW California Cats are suppose to be guaranteed to work for 5 yrs. hence the price......
also like in anything a simple single number change can mean a totally different engine or process... if its exactly the same they would not change numbers
layman terms OBD1 OBD2 its simple number change but a big difference in capabilities.. good or bad... lol
