I havent driven the car yet, still have a few things to finish up (did a m50 swap)
off the bat, the throws are ALOT shorter, its notchy ( which I like), and the position of the knob is great. Its just the right height from the wheel ( you dont have to reach for it like other short shifters because they sit lower). Another thing is obviously you dont have to replace as many bushings because well, there pretty much arent any except for the "bushing" on the shifter itself which really will never go bad or get sloppy.. and if it does, its an easy replacement because its right on the base of the shifter. The base is mounted very solid. no movement at all. Id def recommend it!! a dssr would make it PERFECT.. I have a g260 mounted up to the m50 sooo thats why Im interested in the custom dssr!
Engine and tranny mounts are AKG poly mounts. I wouldnt use stock tranny mounts at the least because since the shifter is mounted on the body as opposed to the tranny, movement can cause it to pop out of gear.. make sense?
If you have any other questions, or if i didnt explain something fully or it didnt make sense, let me know or ask away!
Here is a pic of the shifter installed ( sorry for the bad quality, just ran out to take one with my cell )
