My BMW engine weights guide
  • mooseheadm5
    • Apr 2009
    • 375
    #31
    M70 with all accessories, without harness and injectors, with 4HP24 transmission: 322kg/708.4lb
    M70 with all accessories, without harness and injectors, with flex plate, with starter: 234.8kg/ 516.6lb
    Weighed with my Chinese hanging scale.
    -P
    Moosehead Engineering
    • TimeMachinE30
      • Jun 2014
      • 3749
      #32
      What are the physical dimensions of the M30? L,W & H?
      Trying to get a sense how this thing would fit in my garage.
      ACS S3 Build / Dinan 5 E34
      • downforce22
        • Aug 2009
        • 3192
        #33
        Some additional weights from m5 board member, Anri.
        S14-B23/B25- 415pounds/188kgs
        S38-B36- 587pounds/266kgs
        S38-B38 -602pounds/278kgs(due to heavier dual mass flywheel vs 3.6)
        M88/S38- 530pounds/240kgs
        S54-B32- 522pounds/236kgs
        S50-B32 -(Euro engine) 560pounds/254kgs
        S62-B50 -602pounds/271kgs
        S65-B40 (in a process to find out) my guesstimate is around 560+/-
        S85-B50- 625pounds/278kgs
        The S38 G280 weights 89pounds
        The S38/S54/S62 6spd G420 weights 102pounds
        The S65/S85 weights 135pounds.
        https://www.m5board.com/threads/s14b...weight.500441/
          • 34839
          #34
          Interesting, the S54 ends up being relatively light. Also we know the S65 was heavier than the S54 based on the guy here who personally swapped from an S54 to an S65 - despite BMW claims it weighed less.
          I'd really like to know what a dressed N52 weighs. We have good weights for M20 and M42 already..
            • 34839
            #35
            It looks like the N52 weight here is pretty accurate. I think it is probably a euro engine, with no CATs or AC. 340lbs is probably with A/C and CATs.
            From the N52 swap thread:
            The EKT says the GS6-37BZ weighs 99lbs. The pressure plate is 16lbs, the clutch is 2.4 and the fork is 1.7. the dual mass flywheel is 22.7lbs. Put that all together (without fasteners) and you have 141.8lbs for the full 6 speed assembly (in your pic, there's no shifter, so I'm not counting that).
            The front manifold with cat is 10.8lbs, The rear is 8lbs. Call it 20 total (gaskets, bolts, etc). Aftermarket will probably be lighter, with no cats.
            So 462 + 20 - 141.8 = 340.2lbs, and that's with the AC compressor. Nice.
            I won't be running A/C,, so subtract another 12lbs for 328, fully dressed. That really closely matches the weight listed in this thread, 326lbs (must be without CATs and A/C)
            https://www.r3vlimited.com/board/forum/e30-technical-forums/24v-engine-swaps/385417-n52-swap-discussion?p=9940765#post9940765
            • hoveringuy
              • Dec 2005
              • 2728
              #36
              458lbs. N52 with the lighter G6-17 transmission. No exhaust manifolds, no oil. WITH transmission and engine mounting arms and shifter console and the wiring harness.
              • Genius
                • Jul 2013
                • 54
                #37
                S14 with trans, fully dressed but no Ac compressor w/wiring harness 480Lbs...500 with ac compressor (dry) Click image for larger version
                • downforce22
                  • Aug 2009
                  • 3192
                  #38
                  So I pulled and weighed the M54/G260 combo out of my car today. 475lbs, and that's with 6Qts of oil in the sump and the heavier M56 metal valve cover, without those it would be closer to 460, which is within a few pounds of the N52 with GS6-16 6 speed (458lbs)
                  It's also missing the AC, has the lighter M50 intake and a small alternator.
                  I should have the final weight with new motor mounts and pan, but with the lighter N54 intake and A/C removed.
                  Click image for larger version  Name:	Capture.jpg Views:	2 Size:	67.1 KB ID:	10071129
                  https://www.r3vlimited.com/board/for...11#post9957448
                  • hasa
                    • May 2013
                    • 306
                    #39
                    Please weigh the engine without transmission, if we are talking about engine weights.
                    My N/A race M20B28 was 156kg on a hook scale. Everything between harmonic damper and clutch included.
