M50NV Exhaust Mock-up Choices
  • SkorcherX
    • Jun 2011
    • 267
    Alright... So I just copied that.
    Just ordered a 2.5" Borla Pro XS, and a Vibrant dual tip muffler along with a new O2 sensor, an O2 bung, a y-pipe, and a 6" section of flex pipe. So this would fall under the "Green" mock-up.
    I hope to have this installed the week after next, and can finally drive this thing around town.
    Thanks everyone for the advice.
    • Jand3rson
      • 37587
      Shit, thanks for reminding me, I need to go by the exhaust shop and pick up an 02 bung, totally spaced it.
      • Jand3rson
        • 37587
        For anyone that's considering going from 2-into-1 using the ebay Supersprint rep headers, the Flowmaster Y-Pipe is DEFINITELY the way to go. The spacing is dead-even for the pipes when mounted to the head.
        We cut the downpipes off just after the bend that sweeps them down under the car, and slipped the Flowmaster Y directly over them without any resistance whatsoever. The outer diameter of the headers is a perfect fit for the inner diameter of the Flowmaster Y. For $41 from Jegs, you can't go wrong.
        • jrdeamicis
          • Nov 2008
          • 956
          awww yeah. Thanks for the info!
          Past Car : E30 S50 6 Speed 5 Lug 3.73
          Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
          ___________________________________________
          BNB Designs
          Engine Swaps, Fabrication, Innovation, General Repair
          Richmond CA
          Julian 848-248-8029
          • jclar
            • 265
            Would you happen to have a part number for that y-pipe from Jegs? Looked around a little but their website is terrible to navigate.
            Just ordered eBay headers, a Borla XR-1 and a Vibrant 1040, just need this.
            '86 325es M50
            • Jand3rson
              • 37587
              http://www.jegs.com/i/Flowmaster/389...0002/-1?CT=999
              Here's my Y after being welded to the headers, with the V-Band flange and O2 bung:
              Most of what I've read says the XR-1s are louder than the ProXS. By the way, mine came today:
              • dnick
                • Apr 2011
                • 1377
                well.. seems like ill be doing this too. lol
                • ScHpAnKy
                  • 1573
                  I was planning on running S52 manifolds to the E36 Y-collector into a single 2" cat to a 2" glasspack into a 2" magnaflow straight-through.
                  "planning on" being the quantifying words.
                  91 318i | 87 535iS
                  • ForcedFirebird
                    • Feb 2007
                    • 8300
                    How bad is it to bolt up the headers with the y-pipe welded?
                    john@m20guru.com
                    Links:
                    • drez14
                      • Jun 2011
                      • 211
                      I have an s52 swap im almost completed with. What setup would be best for a Cali Car? do i need to run 2 cats, one for each bank. So i would go with one of the x pipe setups?
                      My original plan was to run Ebay Reps and a stock e36 M3 catback. but i cant figure out how the midpipe should be designed.
                      I dont know why i cant wrap my head around how to do this exhaust. It seems there are too many variables/ways to do it.
                      • Jand3rson
                        • 37587
                        Not bad at all. We welded the Y to the headers while they were bolted to the head, so the spacing was kept perfect. Even after blasting and ceramic coating, they still slip right on. We installed the motor with them bolted up, as well.
                        • 619E30
                          • 1753
                          Red or black.
                          Originally posted by audiquattrot
                          bimmers b4 b*tches....remember that.
                          1990 Alpinweiss 325i - secret 500whp build
                          2000 Audi S4 B5 Laser Red
                          1990 Nissan 240sx - Drift Missile
                          2006 CBR600RR
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            Ah, OK. Was wondering since they appeared to be fresh welded off the motor, but hard to tell in pics sometimes.
                            One of the first sets of headers I made, the flanges got warped from being in a clamp, not on the head. Had to shave them flat, learned my lesson that first time lol.
                            john@m20guru.com
                            Links:
                            • johnjohnsons54
                              • Mar 2012
                              • 228
                              Chambered mufflers can actually be louder a lot of the time, but a lot of it has to do with your piping size. They don't have any sound deadening material in them, just a series of baffles and chambers, which depending on the design, can make it a lot louder.
                              The Borla Pro XS mufflers are supposed to be some of the quietest mufflers available, I've done tons of research online and it looks like what most people choose for quieting their system down.
                              Check out the video I posted above, I'm actually building the exact same system that's on that car.
                              Ebay headers - Y pipe - single 2.5" - Borla Pro XS - Single 2.5" -
                              Vibrant
                              Bump for impressions or a vid of this set up? Ballpark cost if you don't mind me asking? Like most of you guys, I'm looking for a nice set up that flows enough, is civil around town, and has a good deep snarl when you really get on it.
                              I've currently got a a low hanging dinan e36 exhaust fitted to my car and it hangs a little low for my taste. The muffler is also huge for an e30 IMHO.
                              ZF320 | M50 Mani | TRM + 21.5lb Injectors + 3.5in MAF | E36 M3 Rack/Driveshaft | Megan Coilovers | 002R/452's
                              In the works: UUC Evo 3/DSSR, JB Racing lightweight Flywheel, Shrick cams, BBK (yet to be determined)
                              I NEED A WINGLESS AW TRUNK LID PLEASE PM ME IF YOU HAVE ONE!
                              • Jand3rson
                                • 37587
                                I haven't gotten everything welded up yet, but I'm building the exact same setup that e30polak had on his S50 car, should sound nearly identical:
