no fuel/spark at the moment, my car may go to a shop as well :(
24v no start? What was it?
Problem: crank with no start.
Solution: I had a fuel rail without a FPR. It took me a week to figure it out by
clamping the return fuel line with vise grips.Comment
Yes, do this, and check it twice. We fried the ground running from the harness up on the firewall all the way down to the oil pan level sensor because we had a ground hooked to constant power at the distribution block. You DO NOT want to trace a melted wire all the way back through the harness and then replace it, trust me.Comment
woah man, that really sucks. I can't imagine your reaction when tracing the wire through the entire harness. Luckily I had a power to ground so no serious issues arose.Yes, do this, and check it twice. We fried the ground running from the harness up on the firewall all the way down to the oil pan level sensor because we had a ground hooked to constant power at the distribution block. You DO NOT want to trace a melted wire all the way back through the harness and then replace it, trust me.1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IPComment
Yeah, I was pretty fucking pissed. We had to pull the intake manifold and everything around it, and tear apart the whole harness that I had just re-wrapped and zip-tied to the track. We turned the key, and smoke just started rising from under the manifold.Comment
I've had my wires hooked up in different arrangements at the power block and obviously had to have been hooked up backwards a few times. No smoke but how could I tell if my harness could be fried? At the moment no fuel or spark, ICV doesnt buzz and no CEL in accessories/cranking. beginning to get sooo stressful
try hooking up another ECU and seeing if that changes anything. That would be horrible if you fried your ECU, but IIRC your relays will go out before your ECU does. pull off the harness cover and check the connections in there, as well as the connections on your starter, alternator, and power block for any corrosion.I've had my wires hooked up in different arrangements at the power block and obviously had to have been hooked up backwards a few times. No smoke but how could I tell if my harness could be fried? At the moment no fuel or spark, ICV doesnt buzz and no CEL in accessories/cranking. beginning to get sooo stressful
how much did you have to replace?1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IPComment
mine toooooo! sorta. Just one accidental electrical spark in the engine bay. i dont hear the icv eitheri've had my wires hooked up in different arrangements at the power block and obviously had to have been hooked up backwards a few times. No smoke but how could i tell if my harness could be fried? At the moment no fuel or spark, icv doesnt buzz and no cel in accessories/cranking. Beginning to get sooo stressful
Patrick - IG:niicknac
RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, baggedComment
ive been dealing with this issue for like 4-5 months :/ havent figured it out or had enough time to work on it. oh and its my dd (having to barrow parents cars). but i gotta wait till my dad and i can make a jump on the issue
problem: no start because of IAC delete.
Fix: adjust idle screw on TB97 tacoma 5 spd 4 cylinder
2001 330ci 5 speed
83 733i 5 speed, (FS)Comment
