24v no start? What was it?
  • mattrabbit
    • Aug 2011
    • 122
    #31
    Mine would crank but not start, it would start with starting fluid but even priming the fuel pump by jumping it didn't get fuel into the motor. After changing the whole harness out I figured out that I had a bad fuel pump relay.
    • Jand3rson
      • 37587
      #32
      Originally posted by SwiftE30
      how much did you have to replace?
      All the way from the oil pan connector up to the main harness on the firewall, it melted almost the entire length of the wire.
      • SwiftE30
        • Jun 2010
        • 998
        #33
        that really sucks. what a nitemare! so glad i had kinda the same problem but opposite.
        gotta check the simple things first man
        1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
        • e30shmobberr
          • 1934
          #34
          haha realized i didnt even put my fix into this thread,
          my issue was that when i cut the x20 off of the harness, i cut be hind where 2 green ignition wires come together into one wire then that wire goes to the x20. so when i did all my wiring, one green wire was used.
          i sat down with the harness on the floor and went through each wire with wiring schematics. i then found my issue and connected the two greens together, and boom
          it started.
          Patrick - IG:niicknac
          RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
          • cormier
            • 380
            #35
            my issue turned out to be main relay. Dirty ICV also didnt help.
            • bubbajan21
              • 1962
              #36
              Fuel lines backwards
              • e30shmobberr
                • 1934
                #37
                awesome, glad some info is going in here
                • GunMetalGrey
                  • Dec 2010
                  • 1499
                  #38
                  Would turn over but not fire, ended up having a ground strap on a spot that was not a ground.
                  • ian e30 318is
                    • Mar 2007
                    • 1809
                    #39
                    Mine wouldn't start due to the starter pin not being in the correct location on the plug. Also didn't have the ICV plugged into the back of the intake manifold so it wouldn't idle lol
                    1991 LS1 Swapped 318is
                    Instagram:
                    https://instagram.com/saltybeast/
                    LS Build Thread:
                    https://www.r3vlimited.com/board/for...s-e30-ls1-swap
                    • e30shmobberr
                      • 1934
                      #40
                      thanks for sharing!
                      • drumad
                        • Aug 2009
                        • 1700
                        #41
                        PROBLEM: Starter pinion (m20) was not aligning with flywheel (m20).
                        SOLUTION: Installed metal shim between block and bell housing.
                        Actually fired up on first start after the above problem was addressed.
                        2008 335i - n54b30
                        1991 318i - m52b28
                        1994 fzj80 - LAND CRUSHER
                        • StewCrew
                          • Sep 2011
                          • 47
                          #42
                          Problem: No power to fuel pump
                          Solution: Found almost all of my fuses regarding ignition were wrong. Also the red wire by the DIAG plug on the m50 harness was plugged onto the power distribuution block, but on the wrong part and not getting any power. Moved the red wire to where the thick starter wire goes on the power block and she fired right up!
                          • e30shmobberr
                            • 1934
                            #43
                            this thread might get useful!
                            • lbreevesii
                              • Aug 2009
                              • 412
                              #44
                              bloody silver label ecu. Swapped for red and I was golden.
                              condition prior to fix was crank, no fuel, no spark. ICV would hum.
                              I don't always wreck cars, but when I do I wreck them into trees.
                              91' 318is S50 swap - The Black Widow
                              • joebwme30s50
                                • Aug 2012
                                • 21
                                #45
                                Mine were connectors in the wrong place.
