24v no start? What was it?
  • NickL
    • 562
    #61
    Had no relays in my harness haha. Don't know how I missed it.
    1987 325is - S52
    • E30DK
      • Apr 2013
      • 13
      #62
      Problem: Weak Crank no spark
      Solution: Water and oil residue in spark plug holes (I didnt pull the engine so i assume thats how it got there) and most importantly GROUNDS GROUNDS GROUNDS. Clean every single on e you can find and then clean em again!!
      • hfabricius
        • 608
        #63
        Problem: No fuel pressure regulator on my fuel rail (95 325i)
        Solution: Swap out for one with an FPR. Works like a charm!
        http://halden-fabricius.tumblr.com/
        • Tico Frank
          • Feb 2011
          • 351
          #64
          Problem: Spark, Fuel but no injector pulse
          Reason: My engine was a 95 with no Fuel pressure regulator on the fuel rail
          Solution: Replace fuel rail with one that has an FPR
          • drummerchubbs
            • 512
            #65
            This is a great thread! I have an auto harness so I'm sure this thread will help me trouble shoot. :)
            SEE THE MOST BORING M50NV BUILD THREAD HERE: http://www.r3vlimited.com/board/showthread.php?t=288275
            • Pl3wA
              • 1589
              #66
              Problem: strong crank, good fuel, good spark, no start. Not even a burble. Megasquirt ecu. Will try everything on this thread
              • Fusion
                • Nov 2009
                • 3659
                #67
                Fuel pump relay died but was measuring main relay.
                I recommend buying the the main relays (main power, f pump, O2 sensor) new.
                They're only a couple bucks.
