Use the Stock Booster - Modify the Clevis
  • E30335i
    • Feb 2014
    • 1035
    #61
    Anyone have issues with the linkage binding? I'm having that issue atm
    • sweet3
      • Oct 2012
      • 749
      #62
      Did you shift the booster over enough/too much? The booster shaft needs to be as straight as possible
      PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
      • E30335i
        • Feb 2014
        • 1035
        #63
        I did 1/2 inch center to center. Maybe I need an adjustment for the linkage. I have the clevis made from 328isjunkie
        • Mpowered
          • Jan 2014
          • 16
          #64
          I found the same...still haven't fixed it and resorted to just using an e21 booster as my intake manifold still wouldn't clear (using e28 535i mounts)
          • E30335i
            • Feb 2014
            • 1035
            #65
            My booster was leaking! Changed and issue is fixed
            • E30335i
              • Feb 2014
              • 1035
              #66
              You guys need to double check your measurements. My booster was leaking internally and now it's good. It's an inconvenience to change as the intake manifold has to be removed but I feel it has it perks.
              • bimmer630
                • 1228
                #67
                I may have posted these before on another thread, but its slow at work and I'm bored. This thread seems to have been revived so I figured I'd share pics of how I did mine. Ive been driving it for 3 (?) years now with no issues. AKG swap engine mounts
                • bimmer630
                  • 1228
                  #68
                  more pics.
                  • bimmer630
                    • 1228
                    #69
                    I had a spare booster and clevis rod which I intended on chopping in half like the OP did.. But when it came down to it, I couldnt remember where I stuck the spare booster.. so I just whipped up the clevis piece out of some scrap stock that was laying around. Theres no binding at all.
                    • mjweimer
                      • Dec 2015
                      • 649
                      #70
                      Back from the dead...
                      Thinking of moving the stock booster for my swap based on this thread. The brakes on my E30 feel perfect and I don't want to risk loosing this with a different booster.
                      Everyone who's done this still happy with the set-up?
                      I will be having a friend TIG the two clevis pieces together to get good penetration and control the heat.
                      • Pepijn
                        • Jan 2017
                        • 3
                        #71
                        If people are interested, I made a clevis from a solid piece of steel. This doesn't require a weld, so it is much stronger.
                        • mjweimer
                          • Dec 2015
                          • 649
                          #72
                          Pepijn - that is a good looking piece. Are you pleased with the fitment/alignment of the booster rod with this part? I assume that you moved the booster over .5" like the original poster did?
                          If you are thinking of making a run of parts I would be interested.
                          • wilholl
                            • May 2012
                            • 518
                            #73
                            Count me in as interested!
                            1988 325 non-letter Seta "Bronzit"
                            1991 325ic "Laguna Green" (Sold)
                            1993 325i "Laguna Green/Silver" (Sold)
                            1998 528i "Artic Silver" m-sport(totalled by drunk driver)
                            2000 528i Titansilber/gray m-sport
                            2000 528i Titansilber/black m-sport(sold)
                            2001 525i Anthracite m-sport(sold)
                            2013 750i Black/Black m-sport "Beast"
                            • Pepijn
                              • Jan 2017
                              • 3
                              #74
                              Didnt have any time to test fit it yet. But I am assuming it would fit like the TS's his self constructed part.
                              Will let you guy's know when the parts are finished.
                              Got some family issues atm, so hopefully will get at it next week.
                              • mjweimer
                                • Dec 2015
                                • 649
                                #75
                                Pepijn - Sounds good - family issues are always priority #1.
                                MJ
