Use the Stock Booster - Modify the Clevis
  • BBDirtbiking
    • Apr 2012
    • 323
    Just did this, and damn is it a pain in the neck to bolt it back on after moving it half an inch. My arm is all cut up from the brake pedal, haha.
    "Bayerische Motoren Werke - freude am fahren."
    Brandon {Current: 1991 318iS, 2007 328i, 2014 X5 xDrive35d | Past: 1992 525i, 1997 528i, 1999 540i}
    • rightcoastbias
      • 449
      Slotted 1/2" and did this.
      M52B28 OBD1 - G240 - S4.10
      Stuff for Sale: 24v swap parts
      • m_dudey
        • 267
        Anyone have an extra clevis laying around? Please PM me.
        • blackhawkimpact
          • 2415
          I'm using the stock booster. I just re-drilled the holes 1/2 to the right. Works like a charm.
          • craiggroves91
            • Oct 2009
            • 3024
            Hows that working out?
            Looks like the easiest way
            1989 BMW 325i SOLD
            1998 BMW Estoril Blue e36 M3/4/5 SOLD
            1987 BMW 325 (The Piece) SOLD
            1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
            • amcink
              • 788
              Subscribed
              • NbAmTwE
                • Jul 2010
                • 148
                Yeah I'm curious as to why we are looking for these options if the above is true.
                UNDER CONSTRUCTION - 24v 325e (future DD), DD 525i
                stripped out e30 rally project - in progress
                M50NV -> M50TU E34 swap underway
                • hwy84
                  • Aug 2009
                  • 190
                  Because it wasn't true for me - and many others.
                  Moving the booster is easy. Affixing the clevis onto the pedal linkage without removing the pedal, or using only half of the clevis, or putting an angle into the booster rod that wasn't designed to be there and often causes brakes that drag and won't return, isn't so easy.
                  This "double clevis" approach solves the alignment issue, and allows use of the stock on and bracket, maintaining the function of the stock system.
                  And it's cheap and simple.
                  Current:
                  1991 325i Sedan - S50 Swap
                  1988 325i Cabrio
                  Past:
                  1991 M3
                  1991 318is
                  1985 325e
                  • craiggroves91
                    • Oct 2009
                    • 3024
                    Wanna make me one :)
                    Im in the bay area
                    1989 BMW 325i SOLD
                    • craiggroves91
                      • Oct 2009
                      • 3024
                      Picked up two spare clevis' today from pick n pull. gonna give this a shot
                      1989 BMW 325i SOLD
                      • bimmer630
                        • 1228
                        OP, first off, thanks for the Clevis idea. I used it, and I think its a better option than downgrading to a smaller booster.
                        I had saved an extra booster to get a clevis and cut in half, Just like your setup.. but somebody chucked it and I already had my stuff all apart so I decided to just make the third clevis leg out of scrap steel. works the same..
                        And I modified the pedal gear bracket to accept the 4th booster nut.
                        • thisizaremix
                          • Jul 2011
                          • 60
                          I just cut half of the clevis off and attached the other half to the left side of the pedal using washers to make up for the difference on the pin. This makes it perfectly straight as if the booster was never moved. I'll get a photo so you can see what I'm talking about...
                          • Mr.SWISS
                            • Nov 2005
                            • 1251
                            24V+ stock /e21 boosters, that's that shit I DON'T LIKE.
                            Originally posted by 325Projectz
                            don't listen to the diagram... listen to mr. swiss.
                            :nice:
                            • dashboardmonkey
                              FUCK YOUR WAFFLES
                              • Jun 2008
                              • 6158
                              I moved my whole pedal box over with the booster. But, I needed my brake pedal a little further away from gas pedal.
                              -Andy
                              • bimmer630
                                • 1228
                                long extensions and swivel sockets are your friend
