BMW Z3M Diff.. Will it fit E30
  • mtlbloodshot
    • Jul 2011
    • 761
    Well, Im sure this is was spoken of somewhere on this forum but I found a wicked deal (locally) on a 3.23 from a Z3M and want a clear answer on if it will fit bolt on.
    Thanks for the patience. Let me know what you guys know about this.
    MY BUILD THREAD
    http://www.r3vlimited.com/board/showthread.php?t=235231
    INSTAGRAM : @luchcolaneri
  • nrubenstein
    • 3148
    Yes
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • mtlbloodshot
      • Jul 2011
      • 761
      I can bolt it on the rear subframe and use the 318is drive axles?
      MY BUILD THREAD
      • evandael
        • Oct 2009
        • 2881
        you have to swap the output flanges, the Z3M's are larger than the E30's.
        • mtlbloodshot
          • Jul 2011
          • 761
          easy task or will I be buzzing for hours?
          MY BUILD THREAD
          • evandael
            • Oct 2009
            • 2881
            depends on the tools you have, i suppose. i doubt it's that hard, but i've not done it.
            • Unearth078
              • May 2008
              • 2623
              easy peasy. you dont need any tools! they simply slide out, maybe needing some force from a mechanical lever. e30 ones will slide right in.
              when you replace you should make a weekend out of it and replace wheels bearings, axles, resealing the diff is simple so do that, and if your feeling frisky; bushings!
              best deal on new axles is bimmerparts.com
              make sure you get the pimp finned rear diff cover. and then invest im redline gear oil to fill that mofo shortly after buying redline stock.
              Originally posted by Lof8
              4 doors allow you to transport more whores.
              therefore, their value is much greater.
              Down to: 89 aw2 332i/4/5 , 70 Sahara 2002
              • VinniE30
                • 2113
                Would it be easier to use the z3m axles than to replace the output flanges with the e30 ones and reuse your old axles? What else would be required if you were using the z3m diff?
                Zinno '89 <24v swap in progress>
                • giantkeeper
                  • Aug 2009
                  • 1416
                  That is where my 3.15 came from, fits perfect. Swapping flanges took all of 3 minutes...
                  Always Always go for the reach around if there is an option
                  • VinniE30
                    • 2113
                    Yeah but I don't see why you wouldn't just use the axles from the z3m if you're swapping the diff anyway since the axles are supposedly an upgrade in strength. I've had an axle break off before, which caused the diff case to snap off around the bushing and drop too.
                    • mtlbloodshot
                      • Jul 2011
                      • 761
                      Id have to buy the axles new or rebuilt. If they fit then using the Z3M axles can always be a solution. Im picking one up tomorrow with 50k Miles on it. Finding one of those in Montreal isn't the easiest thing.
                      MY BUILD THREAD
                        • 34844
                        I wouldn't use 318i axles even though they do fit. eventually, you'll want to upgrade to at least M20 axles.
                        • 20gmr
                          • 404
                          I would swap output flanges and use e30 axles to avoid messing with those rear wheels bearings. They are a pain without the correct tools( as is anything).
                          Dave @ Bimmerbuddies
                          Contact Bimmerbuddies for all your Parts and service needs
                          M20,24V,5spdSwap,Weld,Fab,Tow,Buy/Sell/Trade
                          Bimmerbuddies LLC
                          717-388-1256
                          2971a Roundtop Rd, Middletown PA 17057
                          *Ask about discounts for R3V members*
                          • mtlbloodshot
                            • Jul 2011
                            • 761
                            Nando, I dunno if this changes anything but I have a 91 318is.. Aren't they same as the M20 Axles
                            MY BUILD THREAD
                            • mtlbloodshot
                              • Jul 2011
                              • 761
                              A E30 325i Diff cover looks the same as a Z3 cover. Could it be?
                              MY BUILD THREAD
