BMW Z3M Diff.. Will it fit E30
  • 10Toes
    Me Father Was A Tree
    • Jan 2008
    • 61222
    #31
    Originally posted by mtlbloodshot
    The fit and slide in fine. I actually hear them snap in and lock. It's just that they poke out further then the Z3M flange. I hope its normal and that the M20 axles are shorter
    You did use flanges out of Med case E30 diff not ones out of the 318is small case right? because those are different.
    • mtlbloodshot
      • Jul 2011
      • 761
      #32
      I'm using the ones from my 4.10. 318is uses a small case?
      Looking at a build from
      Jack Benny, he mentions that he uses his stock flanges
      MY BUILD THREAD
      http://www.r3vlimited.com/board/showthread.php?t=235231
      INSTAGRAM : @luchcolaneri
      • 10Toes
        • Jan 2008
        • 61222
        #33
        Small case flanges in a medium case diff is like a hoverboard on water.
        • mtlbloodshot
          • Jul 2011
          • 761
          #34
          Maybe I'm burnt but I don't get what you mean by that
          MY BUILD THREAD
          • agile30
            • 832
            #35
            Your 318is uses a small case differential. The flanges you need are from a medium case differential in the 325s and shit like that. His analogy just was saying it wouldn't work even though it was a bad analogy to begin with.
            Originally posted by Good & Tight
            It takes real man to mount a big woman, all you haters are just scared boys.
            • 10Toes
              • Jan 2008
              • 61222
              #36
              • Roysneon
                • 4505
                #37
                Basically you need output flanges from a 6 cyl e30.
                Originally posted by mbonanni
                I am a pursit now.
                  • 34844
                  #38
                  right, since the 318is uses the same CV shafts as the 6cyl cars, but the diff is narrower, they made the output flanges wider to make up the difference.
                  • mtlbloodshot
                    • Jul 2011
                    • 761
                    #39
                    NANDO, you're the only one who understands me. Basically you're confirming that the output flanges from the 318is are "longer" because they use a smaller case but the same axles
                    MY BUILD THREAD
