BMW Z3M Diff.. Will it fit E30
    • 34834
    No.. The m cover is much different looking.
    • mtlbloodshot
      • Jul 2011
      • 761
      Yes I know but the Diff i got has no cover on it. So instead of purchasing the finned cover, what are my other options/
      MY BUILD THREAD
      http://www.r3vlimited.com/board/showthread.php?t=235231
      INSTAGRAM : @luchcolaneri
      • MattAvino
        • Jan 2011
        • 2147
        This said diff is getting sketchier and sketchier.
        E30 buildy things
        http://www.r3vlimited.com/board/showthread.php?t=195286
        • VinniE30
          • 2113
          The z3m diff cover looks different and is "finned" for better cooling, but it's still interchangeable with the e30 cover.
          Zinno '89 <24v swap in progress>
          • mtlbloodshot
            • Jul 2011
            • 761
            Thank you Vinni..
            MY BUILD THREAD
            • Sjoerd320i
              • Jun 2012
              • 11
              Originally posted by mtlbloodshot
              Nando, I dunno if this changes anything but I have a 91 318is.. Aren't they same as the M20 Axles
              Yes, they are all the same.
              • mtlbloodshot
                • Jul 2011
                • 761
                Bringing this thread back to life.
                Today, I tried to put my output flange from my E30 diff. They slide it nicely but, my only question is.... Is it normal that they poke out more then the original Z3 flanges?
                Are the E30 half shafts shorter than the Z3s?
                MY BUILD THREAD
                • 10Toes
                  Me Father Was A Tree
                  • Jan 2008
                  • 61222
                  Yeah, that's why you have to swap them.
                  • mtlbloodshot
                    • Jul 2011
                    • 761
                    Why are my output flanges not the same?
                    MY BUILD THREAD
                    • 10Toes
                      • Jan 2008
                      • 61222
                      The one on the right is missing the dust shield.
                      • mtlbloodshot
                        • Jul 2011
                        • 761
                        Ohhh I thought it was one solid piece.. Now that you mentioned it, I checked realoem and you're right.
                        Can you help me with my first question about the e30 flanges sticking out more?
                        MY BUILD THREAD
                        • 10Toes
                          • Jan 2008
                          • 61222
                          Yeah the half shafts are different lengths for the E30 vs Z3m or the bolt pattern might also be different but I'm not 100% sure.
                          • SHunter
                            • Dec 2010
                            • 154
                            I don't know if this applies to your situation or not but I used a 3.15 Z3 diff from a non-M car in my swap. I didn't change axles or stub axles, I just put it in. I've done this twice and never needed to swap anything. Maybe the M cars have a different bolt pattern though?
                              • 34834
                              Z3 M's have bigger CV shafts
                              I haven't seen one in person with the stubs swapped but the cases are the same. it should be fine. perhaps you didn't push them in far enough?
                              • mtlbloodshot
                                • Jul 2011
                                • 761
                                The fit and slide in fine. I actually hear them snap in and lock. It's just that they poke out further then the Z3M flange. I hope its normal and that the M20 axles are shorter
                                MY BUILD THREAD
