What guibo to buy?
  • timmy
    • Jun 2012
    • 52
    What guibo to buy?
    I have a 86' 325es swapped m50v and need to buy a new guibo. How do I know what guibo to buy? Its the getrag 260 trans
  • e30shmobberr
    • 1934
    im using a e36 m3 guibo, but that with a s50. pretty sure the stock e30 one will work for you, anyone else concur?
    Patrick - IG:niicknac
    RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
    • mitchlevy7
      • Aug 2011
      • 672
      it depends on your driveshaft/trans output shaft setup. after a certain date (86 or 87) the guibo changed sizes.
      check real oem for the part number, using the build month and year from the car the trans came from.
      iirc one has 12mm bolt holes, and the other has 10mm and they are different dizes overall.
      www.cp-e.com
      1989 Zinno 325i m52 turbo coupe
      2015 Ford Fiesta ST, Daily Driver.
      • Roysneon
        • 4505
        Use the guibo that matches your transmission.
        Originally posted by mbonanni
        I am a pursit now.
        • timmy
          • Jun 2012
          • 52
          bump? does anyone know if an 86 had a large or small guibo?
          • reelizmpro
            • 9538
            All depends on the manufacture date. Have a look and verify.
            88 M3 - LACHSSILBER
            89 M3 - ALPINEWEISS II
            • timmy
              • Jun 2012
              • 52
              i have my vin where can i look that up?
              • reelizmpro
                • 9538
                I believe its 5/86 but Jack the car up and look. It's not that complicated and the only way to be absolutley sure.
                88 M3 - LACHSSILBER
                • Roysneon
                  • 4505
                  Just get under and look as Barry said. Small guibo has m10 bolts, large has m12.
                  I am a pursit now.
                  • Adrian_Visser
                    • Jun 2006
                    • 2823
                    Large guibo cars can use e36 guibos IIRC.
                    '89 Alpine S52 with goodies
                    • McGyver
                      • 4633
                      just dont buy chinese when you figure the size out. spend the extra $20 for a Lemforder.
