Please help save my marriage
  • Fusion
    • Nov 2009
    • 3659
    First I would jump the fuel pump relay with a good wire to fully rule out faulty relay. I don't remember the pins that need to be connected (85-87?).
    If still no crank, I'd leave the jumper and pull a temporary wire from the relay directly to the pump to rule out immobilizer or faulty wiring between relay-pump.
    If still no worky, than the pump has to be bad or just rusted stuck. Sometimes all they need is a whack to the top.
    Just rule out things that are known to fail.
    • evilm3chic
      • Jun 2006
      • 13
      Awesome I will try these asap thanks a bunch I'll keep you updated
      • Vtec?lol
        • Dec 2009
        • 3278
        Leave yuor husband.
        • nrubenstein
          • 3148
          I would just put an inline fuse in and run a wire directly to the battery for starters.
          2002 BMW M3 Alpinweiß/Black
          1999 323i GTS2 Alpinweiß
          1995 M3 Dakargelb/Black
          - S50B32/S6S420G/3.91
          1990 325is Brilliantrot/Tan
          1989 M3 Alpinweiß/Black
          • joebwme30s50
            • Aug 2012
            • 21
            Connectors in the right place?
            • Boostesi
              • May 2011
              • 220
              had the same issue when i first finished my swap, i initally made a jumper wire and gave 12 v to the fuse for the fuel pump and the car ran, it ended up being a shitty connection in the trunk at the battery + terminal there was a brown wire with a ring terminal on it that had seen better days, replaced terminal, car runs fine now.
              sigpicFellow e30 enthusiast
              Dont waste your time hating, aint nobody got time fo dat
              1986 bronzit 325es- SOLD
              1987 delphin 325i- parts car
              1990 scwarz 325is- m50 drift slut
              CHECK OUT THE BUILD!
              http://www.r3vlimited.com/board/showthread.php?t=229234
              • shiboujin
                • Feb 2006
                • 2791
                You positive you're getting spark? Do you know if the injectors are firing? If you get spark, it has nothing to do with the auto trans wiring in any way. The neutral bypass stuff will keep the motor from even turning over. So if the motor spins over, it isn't any of that.
                What year/model is your car? Can you post wiring diagrams? Either you have something plugged in wrong or the wiring isn't right.
                • evilm3chic
                  • Jun 2006
                  • 13
                  We finally got around to checking a few things out yesterday, we jumped the fuel pump relay and got power to everything, fuel pump fuse and fuel pump but still no fuel. So I have to buy a new fuel pump since that seems to be the issue, I just replaced it a year ago so I never would have guessed that was what was wrong.... hopefully this fixes everything and she'll fire right up. Keeping my fingers crossed
                  • vandy
                    • Nov 2011
                    • 130
                    May I suggest a TRE fuel pump? I'm using them in both of my e30s, I like them! Check them out here. I'm unaffiliated, btw.
                    • evilm3chic
                      • Jun 2006
                      • 13
                      My husband happened to have an extra fuel pump from his honda build so we made it work and IT RAN! Thank the little baby jesus it finally ran, I can't believe it was the damn fuel pump all along. I replaced the fuel pump about 6 months before I took it off the road to do the swap so it was literally the last thing I thought would be the problem. Now I just have to get the exhaust done and tie all the loose ends and she'll be on the road in no time.
                      Thanks for all the help guys! Now I just have to figure out how to talk my husband into helping me turbo the M3
                      • e30rapidic
                        • 2167
                        awesome..congrats
                        '87 325ic, powered by S50.
