Swap 1/4 Mile Thread
  • asubimmer
    • 6482
    #121
    2.5l and 1/8th. I wish there was a 1/4 somewhere close to me :(
    I only got a slow 9.6 @ 74.74 because I had NO traction. I spun 1,2 and 3. It doesn't help that the tires that came on the new wheels have diff back tires w/ diff amts of tread or that I have a 6 puck clutch. Also the wilks is known for have horrible traction in general...
    9.6 isn't too bad but its not what I was hoping for. I really wanted to get into the low 9's or high 8's. I must say though its the first time I have ever drag raced, but it was a lot more fun than I thought it would be. But I am getting some azenis this weekend so hopefully when I make it back out I can get some better #'s.
    • BingM3
      • 863
      #122
      I only got a slow 9.6 @ 74.49 because I had NO traction. I spun 1,2 and 3. It doesn't help that the tires that came on the new wheels have diff back tires w/ diff amts of tread or that I have a 6 puck clutch. Also the wilks is known for have horrible traction in general...
      I still have to hit under 14:( but I like everything in the car though:)
      A/C, seats, spare, etc
      • aeryk7
        • Oct 2005
        • 616
        #123
        I dynoed 215rwhp with my AFR very rich at probably near 8 to 1 the reading fell right through the bottom of the chart which ended at 10 . I was running 21.5lb injectors with no tuning it was a little torqier down low but pigish up top . I am gonna get dynoed again with the stock injectors which have been ever since i wasted money on that dyno
        253rwhp
        My Vids(OLD)
        http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
        http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
        • BingM3
          • 863
          #124
          G-TECH update two days ago
          0-60 5.17 secs
          1/14 14.06
          HP - 230 HP
          • e30polak
            • 6136
            #125
            not bad...i like the 60 time, is that 230 to the wheels? or crank?
            INSTAGRAM: @UNDR8D_EMPIRE
            • BingM3
              • 863
              #126
              Has to be crank, never dynoe'd the car - I found a 506 DME for the build date for my engine and it revs super flat out smooth when you press on it...still my my idle issues on awhile but i hear it is common on the S50 engine....got my T chip which should bump up the idle because of the L/F I have...got the 3.5 HFM, I'll test and post #'s next week, waiting for my 3.5 adaptor from siliconeintakes.com
              • mazur
                • Jan 2006
                • 731
                #127
                I ran my car last night. Forgot how not fun drag racing is, so this will probably be the only time I post times.
                The story: Strip located 1000' above sea level. Tried using r-comps to get a good launch, but have massive wheel hop and couldn't break a 2.3.
                60'- 2.304
                ET- 14.089
                MPH- 101.7
                The car:
                US-S50 w/ ZF tranny and 2.93LSD
                225/50/14 tires
                243rwhp
                After this night, I realized how unreliable 1/4 mile times are on basing how fast a car really is. I really like the idea of using a VBox and doing 60-130 mph times. http://forums.bimmerforums.com/forum...highlight=vbox
                It takes a car's/driver's launching ability out of the equation.
                • PiercedE30
                  • Apr 2005
                  • 4220
                  #128
                  Good time to post the fun I had last night.
                  So, I got to run a buddy of mine in his C6 'Vette. He runs 12.80's consistently and is trapping like 118/117. Well, I just (Thursday) got my 225/50/15 BFG DR's mounted on a set of 5 series steelies (15x6.5 et20). I dropped the tire pressure down to 25 psi (then later dropped them to 23 psi and could feel a difference) even though I should have gone down to 20 psi. Did my burnout, then lined up. Turned on the launch control, brought it up to 4000 and then went. I spun in first up until about 6500-6700. I 60 footed the shit out of him and had him all the way through the 1/8. After that, he pulled around me pretty good and at the end of the 1/4, he had me by like 2-3 car lengths. When I crossed the 1/4 mark my MPH was between 105 and 110, wasn't paying that much attention to the speedo.
                  I look at it this way, once I get my tire pressure in the sweet spot and get the launch control at the correct RPM, then I should be able to pull sub 1.8 60 foot times, as long as I don't snap any axles. There is a test and tune all day next sunday that I am going to hit up after the AutoX gets over with. That will allow me to figure out tire pressure, launch control, maybe play around with the flat shift feature, and I should be able to find the sweet spot. I'll post it up Sunday evening when I get back.
                  Note: I don not recommend street racing. It can be hazardous to your health, and the health of others. Take what I have said lightly.
                  My 2.9L Build!
                  • EtaSport
                    • 2853
                    #129
                    225/50/14 tires
                    243rwhp
                    mods on this 243rwhp s50? sounds stout as hell.
                    Old and improved:
                    • digger
                      • Nov 2005
                      • 6211
                      #130
                      60'- 2.304
                      ET- 14.089
                      MPH- 101.7
                      The car:
                      225/50/14 tires
                      243rwhp
                      60-80 would be plenty represenative..........
                      • 808AWD325xi
                        • Sep 2007
                        • 359
                        #131
                        60'- 2.304
                        ET- 14.089
                        MPH- 101.7
                        The car:
                        225/50/14 tires
                        243rwhp
                        Nice ET/trap
                        Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms/OFT
                        • mazur
                          • Jan 2006
                          • 731
                          #132
                          10# JB racing flywheel
                          3.5'' HFM/Amsoil Filter/silicone intake boot
                          Stickley chip
                          Ceramic coated Ebay headers/single 2.5'' with hi-flow cat
                          removed stock clutch fan
                          ...that's pretty much all the things that can account to my horsepower gains, but I also have 24# injectors.
                          My engine has always made higher than average power, so don't assume you'll make the same amount with same mods. My friend with very similar mods on his s52 E36 M3 dynoed only 247rwhp, but also has Schrick cams, BBTB and UUC underdrive pullies. :p
                          • zav3n
                            Curious George!
                            • Mar 2007
                            • 223
                            #133
                            not really and traction in 1 and beginning of 2nd but overall a decent run for a m50...
                            9.6@74
                            • Jean
                              • 18228
                              #134
                              1/8... what's with all the horrible 60' ?
                                • 37834
                                #135
                                My best of 2 runs was a 9.2. The clip came off my gas pedal at the end leaving me with only half throttle.
                                1/8 mile tracks suck! Too bad they closed LACR, the only 1/4 mile track around.
                                Grover Beach, California
                                BimmerHeads.com
