24v - Vibrant muffler = Me not happy
 Here's an idea of how mine sounds, not great quality, but whatever
 2 2 1/2" from exhaust manifolds---->dual 2 1/2" in to single 3" out----->3" in/out Vibrant Ultra Quiet Y-pipe converter----->3" in and dual 3"out Vibrant Streetpower stealth
 Last edited by craiggroves91; 02-23-2013, 10:23 PM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
 1989 BMW 325i SOLD
 1998 BMW Estoril Blue e36 M3/4/5 SOLD
 1987 BMW 325 (The Piece) SOLD
 1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207Comment
 Can you elaborate on your ceramic coating? Who did it and what temp coating did you get? I am looking at jet hot sterling right now for s38b36 headers which can get extremely hot in a e30's cramped engine bay. Comment
 I highly recommend these guys
  Introducing VADER v3.0 THE ART OF EXCELLENCE Buy No Serrations We didn't buy into the "serrated circle edge" concept of locating the cap. Using hardened steel dowel pins is the only way to fully achieve strict cap alignment and maintain bore concentricity under brutal conditions...all the time and every time. F1 Beams A completely redesigned Introducing VADER v3.0 THE ART OF EXCELLENCE Buy No Serrations We didn't buy into the "serrated circle edge" concept of locating the cap. Using hardened steel dowel pins is the only way to fully achieve strict cap alignment and maintain bore concentricity under brutal conditions...all the time and every time. F1 Beams A completely redesigned
 Coatings are amazing.Comment
 In bold is part of your loudness problem. No need for 3" piping on an NA motor. It's actually amplifying the sound.
 It was done at the same shop here in Bend that does all of my PC work. I don't know the temp specs, I could probably find out. I considered JetHot, but the shipping hassles turned me off. It was much easier to find a place locally. Cost was about $14/ft.Comment
 1985 325e M50TU(Sold)
 1991 318is Slicktop (Sold)
 1990 325is Brilliantrot S50/5 Lug Swapped.
 1992 525i Manual shitbox Winter BeaterComment
 1989 BMW 325i SOLD
 Originally posted by evandaela car is a car. call it a dildo, i'd still drive the hell out of it.Comment
 hmm, in actuality it looks more like the 10416, I'm not exactly sure on the exact model# but the actual muffler is around 12" in length with entirety around 20" in length with a 2.5in and out diameterComment
 No. In a typical 6-2-1 E30 exhaust, everything past the last exhaust collector is trivial. Single 2.5 or 3.0 tubing post-merge will have an infinitesimal effect on power.
 So what DOES affect power?- Exhaust primary size and length. People with Racelands are leaving area under the curve on the table as the primaries are HUGE.
- The quality of the merge also has an effect, though it is smaller in comparison. You can't see the quality of the merge from the outside, but if there is poor, bulky welding and bad pipe fitup, you stand to lose a whp or three at the highest flowrates.
- The geometry of your second merge collector (2 into 1) will also affect power-- angle of the merge, the size of the choke, length and angle of the post-choke transition (commonly called a megaphone).
 It is not amplifying the sound. It is harder to damp the sound as efficiently. By sizing pipe smaller, you make it easier to quiet down an exhaust system from a geometry standpoint--that is, the smaller the piping is, the easier it is to quiet down a system by using smaller mufflers/resonators. So if you have a 3" exhaust, you must choose larger mufflers. Comment
