My m50 is pinging. Running out of ideas.
  • e30austin
    • 15382
    #46
    I would just do them all, just so you know. My old m50 ran like shit and got terrible mileage, so I replaced the blue coolant temp sensor and it woke it right up and got my mileage back.
    • Wishno87
      • 6025
      #47
      Awesome. Thanks for the advice!
      My plugs 1-6 from right to left
      • e30austin
        • 15382
        #48
        Go get the NGK plugs. That was the other half of my issue. Never ran right with the Bosch plugs.
        • justin_l_
          • Jun 2007
          • 1079
          #49
          Ngk ftw
          • Matt-B
            The Waffler
            • 3856
            #50
            Those are oem. Im running them with no issues.
            Josh if you to barrow parts lmk
            • Wishno87
              • 6025
              #51
              Ryan you figure anything out on your end?
              • Ryann
                • 3350
                #52
                Updates?
                • Ryann
                  • 3350
                  #53
                  I've tried unplugging coolant and intake air sensors, no change.
                  • Wishno87
                    • 6025
                    #54
                    I got my fuel pressure tester yesterday. Trying that today or tomorrow. I put some "upper cylinder cleaner" in my tank and running that through. It specifically mentions it is supposed to clean piston tops. If fuel pressure checks out I will probably be doing seafoam next after I peek in the bores with an inspection camera.
                    • Dj Buttchug
                      • Jun 2010
                      • 7688
                      #55
                      just did new O2 sensor. Problem solved on mine...
                      Turbo M42 Build Thread :Here
                      Ig:ryno_pzk
                      I like the tuna here.
                      Originally posted by lambo
                      • Ryann
                        • 3350
                        #56
                        Hmm, makes sense so far as only pinging when warm (closed loop).
                        • Wishno87
                          • 6025
                          #57
                          I guess that's next on the list for me lol.
                          • Dj Buttchug
                            • Jun 2010
                            • 7688
                            #58
                            this x345422
                            go to a parts house. Buy A 1995 ford mustang 4 wire O2 pre cat sensor.
                            38 bucks.
                            done
                            Ig:ryno_pzk
                            • Wishno87
                              • 6025
                              #59
                              Just ordered one. Should have it this afternoon. Will update with results.
                              • Wishno87
                                • 6025
                                #60
                                Well no dice on my end. It might be slightly better with the new sensor MAYBE. Or that could just be placebo. Fuel pressure and seafoam next.
