Markert Motor Works Dyno Thread (many inside)
  • 328ijunkie
    • May 2007
    • 3961
    Originally posted by ForcedFirebird
    That torque jump...
    Check Us out on Facebook
    Full Product Line Tuning
    • surebimmer
      • Jan 2004
      • 978
      Are these OBD 1 tunes or OBD 2. Or does it not matter? Can you remote tune?
      • Aviator
        • 616
        Wow, that s52 is healthy!
        84 325e Burgundrot S52 M Tech 1.
        http://www.r3vlimited.com/board/showthread.php?t=250109
        • ForcedFirebird
          • Feb 2007
          • 8300
          Originally posted by 328ijunkie
          That torque jump...
          Under curve :)
          So many people only look at peak.
          john@m20guru.com
          Links:
          • DesertBMW
            • Aug 2011
            • 1030
            Have you ever spent any time tuning on a dyno? I have before/after that gained 40wtq and 40whp. Same dyno, same day, consecutive runs. :)
            So you took naturally aspirated 6 cylinder BMW car stock with stock tune then did a dyno run then tuned it then did another dyno run and made 40hp/40tq?
            • 328ijunkie
              • May 2007
              • 3961
              By the looks of it be did ~40 runs and picked up at max delta 30 in the midrange...
              • digger
                • Nov 2005
                • 6120
                • RobertK
                  Kicked cancer's ASS.
                  • Jun 2005
                  • 5864
                  All kinds of HPs and TQs and stuff. I'm diggin' it.
                  • Bimmian89
                    • May 2012
                    • 170
                    Dave is the Fk'n man!
                    Check out my build thread!! :p
                    http://www.r3vlimited.com/board/showthread.php?t=288383
                    • mpowerful
                      • Jul 2013
                      • 1273
                      Dave do you do charity case tunes hahaha?
                      Serious question though i noticed you changed the site up and didnt see any reference to obd1 tune prices. How much would it be to do a obd1 dyno tune? Do you have an emulator you can plug up for dyno then flash final tune to a chip?
                      • 328ijunkie
                        • May 2007
                        • 3961
                        I personally hate doing obd1 stuff. For one, don't have an emulator so I'm constantly flashing chips at dyno, in addition to that the obd1 cars I have tuned I've never been happy with. They usually don't come to me working/running at 100% and tuning them is a headache. Sometimes I'll do 3 runs without changing a single
                        Thing and the hp/tq will waver by 20
                        For whatever reason. Also
                        The knock sensor feedback is abismal so max power dyno tuning is fun...
                        • DesertBMW
                          • Aug 2011
                          • 1030
                          Are you saying you have the 28F200 emulator for MS41 and you do real time tuning on a dyno?
                          • 328ijunkie
                            • May 2007
                            • 3961
                            I have an emulator. Do I use it at dyno? No. Reflash time is ~49 seconds so don't really need it. Only thing I use it for is full flashes (256k)
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              Red label 413 s52 swapped e30 with forged pistons (10.5:1), sunbelt cams, obd1 manifold, 3.5" MAF, 24lb injectors and long tube headers. Same dyno same day, same tuning session. It probably would have done a little better if it was left to cool down, it was pretty heat soaked by the end. The first pull was a very popular companies mail-order chip made for this particular combination.
                              I use TunerPro RT and an emulator.
                              Yes, right where the RPM's are post gear shift. Didn't pick up peak power, but 30hp at the shift made it a whole new car to drive. Peak torque really moved up as well as area under the curve.
                              john@m20guru.com
                              Links:
                              • digger
                                • Nov 2005
                                • 6120
                                post up the name of the original chip maker? was it is vanos or ignition timing the biggest gain?
