Markert Motor Works Dyno Thread (many inside)
  • 328ijunkie
    • May 2007
    • 3961
    #61
    Tuned a E46M today :P
    Check Us out on Facebook
    Full Product Line Tuning
    • 328ijunkie
      • May 2007
      • 3961
      #62
      Update With a Alum block 2.8L!
      • 2mAn
        Señior Mod
        • 20992
        #63
        I had heard the Alum blocks make less power, doesnt seem to be a big drop VS Iron blocks. I have always told myself, if Im over 200whp when I dyno I will be happy. This makes me anxious
        edit: Can you do an overlay of the Alum M52 VS an Iron M52 with similar mods?
        Simon
        Current Cars:
        -1966 Blue Boat
        -1969 Red VW
        -1986 White BMW
        -2006 Green Thing
        Make R3V Great Again -2020
        • 328ijunkie
          • May 2007
          • 3961
          #64
          Not 100% fair because the E36 (cast) car had a nice exhaust setup, but other than that theyre equal...
          • 2mAn
            Señior Mod
            • 20992
            #65
            Do you think the exhaust would contribute to the higher powerband ? The E36 doesnt seem to fall off as much.
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            • 328ijunkie
              • May 2007
              • 3961
              #66
              Def helped/hurt by the looks of it. Notice the slight torque loss down low...
              • ForcedFirebird
                • Feb 2007
                • 8300
                #67
                That "down low" would never be noticed by the average driver. The exhaust absolutely was the only difference. Things look so much more dramatic in a side by side comparison.
                IMO if anything, the AL block "should" make slightly more with all else equal, since it does have better and more consistent heat transfer with the m52tu/m54. Engines tend to make more power when cylinders are balanced.
                Good job on all the dyno work, Dave.
                john@m20guru.com
                Links:
                • digger
                  • Nov 2005
                  • 6192
                  #68
                  i'd also be careful drawing too many conclusions of comparing different engines in different cars.
                  • 328ijunkie
                    • May 2007
                    • 3961
                    #69
                    Added another M52 w/ cams/manifold. Highest one ive dynoed thus far!
                    • 328ijunkie
                      • May 2007
                      • 3961
                      #70
                      Added a S52 and another RB135 ;)
                      • 2mAn
                        Señior Mod
                        • 20992
                        #71
                        those 135i's make crazy power. I wonder how they would be running on Californias 91octane + your tune
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        • 328ijunkie
                          • May 2007
                          • 3961
                          #72
                          Tuned a M54 swap today. Threw some graphs up ;)
                          • ian e30 318is
                            • Mar 2007
                            • 1809
                            #73
                            Wish you were in California...I need my s50 dyno tuned soon.
                            1991 LS1 Swapped 318is
                            Instagram:
                            https://instagram.com/saltybeast/
                            LS Build Thread:
                            https://www.r3vlimited.com/board/for...s-e30-ls1-swap
                            • 328ijunkie
                              • May 2007
                              • 3961
                              #74
                              Tuned a blown S52!!!
                              • 328ijunkie
                                • May 2007
                                • 3961
                                #75
                                Tuned some more SC S52s and a S54 swap we did.
