300whp S52?
  • HennaE30
    • Apr 2014
    • 1965
    300whp S52?
    I hate to be that kid who posts the noob ass questions like this, but me and a friend were discussing this earlier and weren't sure. He thought it was possible, but I wasn't sure.
    Is it possible to get 300whp out of an S52 with "basic" bolt ons and some porting? The plan is to rebuild my buddies S52 for my E30. Not gonna mess with the bottom end, just get new bearings and seals and have it cleaned, then rebuild the head, run stock valvetrain aside from some porting, super tech valvesprings, and cams. Then have an M50 manifold, 24# injectors, 3.5in MAF, KAMotors intake, headers/full exhaust, a tune for 93 octane and under drive pullies.
    Is 300whp an achievable goal without major work? What kind of numbers would this set up most likely bring? I'm not looking to go FI. Also, out of curiosity, does anyone make an S52 ITB kit?
    Thanks
    Originally posted by flyboyx
    how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
    Originally posted by Northern
    beer is my new liver cleanse.
    Henna - '84 Hennarot 325e
    Lola - '89 Schwarz 325is - being saved
    Christine - '88 Schwarz 325is - Spec E30 Racecar
    '01 White F150 Lariat 4x4 Supercrew - Daily
    Dad's '05 Interlagosblau M3
  • rturbo 930
    • Dec 2005
    • 2627
    Nope.
      • 34844
      No
      • HennaE30
        • Apr 2014
        • 1965
        I didn't think so, I figured that'd be around 240whp (or 275 crank) it's a healthy motor (dynoed out to 208whp with just a lightened flywheel), and that's after 170k miles.
        • mpowerful
          • Jul 2013
          • 1273
          Throw some super nasty cams in there and you may get closer.
          • digger
            • Nov 2005
            • 6198
            you will get reasonably close if you know what youre doing, the only difference between a built bottom end vs a fresh one in terms of power is basically the compression. sure things will be a little lighter reciprocating wise which also might show a few hp on a dyno but its not going to be massive.
            saw an allmotor 290whp S52 dyno just last week with OEM type manifold, albeit on Dynojet STD correction. you will needs cams that hurt that bottom end to make the numbers get close
            • HennaE30
              • Apr 2014
              • 1965
              Lol.. The car has to be streetable.. Hopefully it won't be a DD anymore once it gets swapped.
              • digger
                • Nov 2005
                • 6198
                • justin_l_
                  • Jun 2007
                  • 1079
                  You can pick up a used charger for the price of a good set of cams and see 300. I know you said you wernt looking for FI but something to think about.
                  • totheredline
                    • Jun 2013
                    • 762
                    330hp. Metric mechanic motor. Deff a fully built AF motor tho
                    = Heidi 1988 325 -> 335i. 7200rpm built M30
                      • 34844
                      MM tends to inflate their hp claims, but even if it did make 330hp (which I presume is at the crank) it would cost like $20,000. you could have just bought an S54.
                      • FredK
                        • 14763
                        Yes, BMW CCA IP engines put down around 280 to 295 whp. The recipe is basically the same. It's mostly stock parts, stock induction, efficient headers, and big cams. I do not believe the IP class allows for much machining to be done, or have a non-stock intake manifold.
                        I bet if you did some intake tract optimization that you could get that extra power and then some.
                        • HennaE30
                          • Apr 2014
                          • 1965
                          Was talking to a buddy about picking up a used kit and running a low boost application.
                          • 328ijunkie
                            • May 2007
                            • 3961
                            The low boost SC kits we install/tune churn out 300-330whp. 300whp NA is a tough feat but can be done if you have deep pockets and dont mind it coming apart after a few thousand miles...
                            Check Us out on Facebook
                            Full Product Line Tuning
                            • ForcedFirebird
                              • Feb 2007
                              • 8300
                              Originally posted by 328ijunkie
                              The low boost SC kits we install/tune churn out 300-330whp. 300whp NA is a tough feat but can be done if you have deep pockets and dont mind it coming apart after a few hundred hours...
                              FTFY
                              Most high strung engines as such are rebuilt every season, if not more.
                              john@m20guru.com
                              Links:
