Turbo time for my S50 on a "budget"
  • BMW_TUNER
    • Jul 2006
    • 1386
    #121
    Direct vent boost control.
    1989 332IS -S-Fiddy Four-Some weight removed.
    5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
    • TheTacoMan
      • Nov 2011
      • 2308
      #122
      Looks awesome.
      • BMW_TUNER
        • Jul 2006
        • 1386
        #123
        For now it's just proof of concept. Once I know it can hold boost down by itself I will be plumbing it right into the downpipe.
        • BMW_TUNER
          • Jul 2006
          • 1386
          #124
          Might have to go to a Turbosmart hyper gate to get clearance for the hood. Fun
          • BMW_TUNER
            • Jul 2006
            • 1386
            #125
            Test run shows a great hold capability. Holds almost a perfect 11psi.
            • JOMARO
              • Mar 2006
              • 116
              #126
              its weird you have issues with your wastegate
              I have the same manifold with the same 44 Tial MVR routed to my 3" downpipe and I dont have any issues @ 13 psi !!
              where do you get your wastegate vacuum line ? I tried it form the compressor housing had some issues , then I tried it from my intake manifold and it worked flawlessly
              My G260 is also is still holding @ 400 whp
              although my Lsd 3.25 started whining:(
              • BMW_TUNER
                • Jul 2006
                • 1386
                #127
                Yeah I think the GT3582r is to spook happy to make low boost with the manifold.
                • Northern
                  I like cupcakes & sh!tboxes
                  • 5284
                  #128
                  Right off the turbine housing? I was thinking about doing that or trying to route the current tube up beside the downpipe, but haven't decided.
                  Originally posted by priapism
                  Originally posted by shameson
                  • BMW_TUNER
                    • Jul 2006
                    • 1386
                    #129
                    There may be room but the WG wouldn't be in the path of flow if you went under the downpipe and off the existing feed. The WG housing provides me the befit of by very much so in the flow and with any luck the Eboost 2 will be able to ramp me up and down so I can truly use it like a boost selection device.
                    • TheTacoMan
                      • Nov 2011
                      • 2308
                      #130
                      I had to massage my sheet metal a bit to fit the 38mm wastegate on the m20.
                      Good to hear its holding boost now, I doubt you would get traction with 5 psi with the roads the way they are atm.
                      • Northern
                        • 5284
                        #131
                        It would be much more in the path of flow than it currently is on my manifold. Out the current spot, but then 90 off to the passenger side and up to clear the downpipe. Ends up in almost the same spot as yours is now.
                        Only reason I'd bother to do this instead of right on the housing is because the other car already has an external WG, and it would be nice if I could swap turbos between cars.
                        • BMW_TUNER
                          • Jul 2006
                          • 1386
                          #132
                          I think I went from boost creep to boost seep. I was doing some testing and using my Eboost to try to make more than spring 12 psi and I appears that the car is not happy with that. I think the wastegate location and 10# spring can't keep it closed with the wastegate top being open to atmosphere. I swapped it for a stiffer spring and I am going to reconfigure to a two sided setup to try to have the boost hold it closed from the top.
                          • agile30
                            • 832
                            #133
                            What manifold is that? I have never seen the wastegate set up that way in an e30 before.
                            Originally posted by Good & Tight
                            It takes real man to mount a big woman, all you haters are just scared boys.
                            • BMW_TUNER
                              • Jul 2006
                              • 1386
                              #134
                              The manifold is a good n tight with the WG capped off. It couldn't keep up with my quick spoiling gt35 so I had the hot side vented directly.
                              • BMW_TUNER
                                • Jul 2006
                                • 1386
                                #135
                                Project will be getting back under way soon. I have a 3.25 to swap in a ZF320 that has just had the pin service a driveshaft adapter, chromemolly axel shafts a UUC DSSR and an AKG shifter to install now to mention the solid motor mounts, because the engine is currently rocking 2 inches to the right under load. Then I can get to the dyno and hopefully start to get the AFR's in the 11s at redline under WOT.
