Turbo time for my S50 on a "budget"
  • BMW_TUNER
    • Jul 2006
    • 1386
    #151
    Pulled the head and came. They are in great shape. #2 piston is sitting 6-7mm lower than the rest. Apparently I was making to much power for the forged K1 H beam rods. Hope to pull the motor tomorrow and lay the rods on the bench I have a feeling the bend is significant.
    1989 332IS -S-Fiddy Four-Some weight removed.
    5 lug E36 M3 Brakes Coilovers and LTW's and No ABS.
    • BMW_TUNER
      • Jul 2006
      • 1386
      #152
      • TheTacoMan
        • Nov 2011
        • 2308
        #153
        Ive never seen that, crazy...
        • BMW_TUNER
          • Jul 2006
          • 1386
          #154
          It reminds me of that college question
          What is the fastest way between any two points on the face of the earth...........
          a curved line, a zig zag or a straight line. Lots of people say a straight line but the earth is curved. HAHA.
          Given that it has dropped I could drag out some old geometry and trig and figure out the arc before I pull the bottom end but at this point its safe to say that its bad.
          • BMW_TUNER
            • Jul 2006
            • 1386
            #155
            If this is #2 Rod he ain't that straight any more.
            • ian e30 318is
              • Mar 2007
              • 1809
              #156
              So are you replacing rods and keeping the turbo setup?
              1991 LS1 Swapped 318is
              Instagram:
              https://instagram.com/saltybeast/
              LS Build Thread:
              https://www.r3vlimited.com/board/for...s-e30-ls1-swap
              • BMW_TUNER
                • Jul 2006
                • 1386
                #157
                I do not advise anyone purchase K1 Rods. They did this on 12 psi.
                • BMW_TUNER
                  • Jul 2006
                  • 1386
                  #158
                  No moving on to S54 NA
                  • Sh3rpak!ng
                    • Jan 2014
                    • 2667
                    #159
                    Jesus wtf
                    Sent from my SM-G920T using Tapatalk
                    Shadetree30
                    • Dagamus(NM)
                      • 621
                      #160
                      Jeez, that is crazy. I wonder if others have had this experience.
                      Gun control means using both hands
                      Sex, Drugs, Rock 'n roll. Pick two.
                      • BMW_TUNER
                        • Jul 2006
                        • 1386
                        #161
                        According to a quick google search....yes.
                        • Dagamus(NM)
                          • 621
                          #162
                          Yeah, google did confirm that. I wonder how their failure rate compares to others. Was it predetonation that caused this?
                          Megasquirt plug and play is sounding better and better.
                          • BMW_TUNER
                            • Jul 2006
                            • 1386
                            #163
                            Very unlikely as the timing was concervative and the comp ratio was so low.
                            • Dagamus(NM)
                              • 621
                              #164
                              So just gross material failure? No evidence of hydrolock...
                              • BMW_TUNER
                                • Jul 2006
                                • 1386
                                #165
                                It is all out material failure. I think JE should stick to making Pistons those looked good on disassembly.
