does the original reservoir only interfere with the TPS on an M50/S50? Would the top mounted S52 fit fine?
M50 swap that will blow your mind.
Some updates
The smaller reservoir that you can buy will fit in the master cylinder with the smaller grommets but the clutch master cylinder hose would have to be extended and the e9x reservoir can fit with some “massaging” with the m52/s52
Here’s some pics.
Sent from my iPhone using Tapatalk ProOnwer of
1987 e30 325e soon to be s50
1991 e30 318i four door
1994 e34 530i 5speed
05 e53 X5 4.4i fully loadedComment
Great pics thanks for the update! One question, is there a negative effect from having a smaller reservoir?Comment
Where is that smaller resevoir from?Comment
Onwer of
BTW does any sensor cap fit? Like the E92 cap will fit the new smaller reservoir.Comment
Functionality update
Took it for a short drive (no exhaust yet after headers). Stomped on my brakes a few times in isolated safe areas. This booster upgrade is the shit. Feels like a newer car. Yet I'm sure my old e30 booster has definitely seen better days. Thanks for the photo cred brotha and being adventurous enough to find this booster option!Comment
If you have a large piston volume in your BBK, and top off the reservoir when you have new pads, then you might drain the reservoir as your pads wear thin. If you're in this situation and top up the reservoir along the way, you'll overflow it when you push the pistons back to install new pads.Comment
