M50 swap that will blow your mind.
  • jjc034
    • May 2018
    • 107
    #91
    Originally posted by Noshow20x96
    This is one of the reasons why I went with the e9x booster and I kept reading that the diaphragms on the 944 boosters break internally, very common.
    Sent from my iPhone using Tapatalk Pro
    I have a 944 and will be swapping to an e90 in the future
    Sent from my SM-G930V using Tapatalk
    • Noshow20x96
      • Dec 2013
      • 144
      #92
      [emoji106]
      Onwer of
      1987 e30 325e soon to be s50
      1991 e30 318i four door
      1994 e34 530i 5speed
      05 e53 X5 4.4i fully loaded
      • jjc034
        • May 2018
        • 107
        #93
        [emoji106]
        How much whp am I gonna get? Lol
        • Noshow20x96
          • Dec 2013
          • 144
          #94
          At least 7 whp.
          Onwer of
          • razo-s.supra
            • Dec 2009
            • 124
            #95
            Awesome job man. What reservoir are you doing and the adapters for it. Let me know when you take that thing for a spin.
            I am running the ate remote reservoir , fittings, grommets and BMW hydraulic hose. I'll get the part numbers for you
            • Noshow20x96
              • Dec 2013
              • 144
              #96
              Awesome. Thanks buddy.
              Onwer of
              • razo-s.supra
                • Dec 2009
                • 124
                #97
                remote reservoir
                [QUOTE=Noshow20x96;4922811]Awesome. Thanks buddy.
                34311121911 qty of 2 $2.70
                34321102282 qty 2 $ 4.75 ea
                21521163714 qty 1 $11.84
                34321112399 qty 1 $18.04
                • digger
                  • Nov 2005
                  • 6154
                  #98
                  Is this 1" or 2" smaller diameter than the stock m20 booster ?
                  • Staszek
                    • 2533
                    #99
                    Its a little over 1" smaller, its similar to the XI booster, except its not as deep, and the master is shorter as well.
                    • yasnick.ramputty
                      • Jan 2015
                      • 9
                      #100
                      Originally posted by pazi88
                      IF you jump around between e30 and newer cars, the difference how much brake power you need to apply is quite big. Which is quite annoying and because of the brake feel the e30 feels like outdated car. Which it is :D So I at least would much rather get the same new car feel to the e30 brakes also.
                      And inspired by this thread, I also got myself e90 booster. 50€ from ebay and in like new condition. Going to install that to my car next winter when the driving season ends here.
                      But well. Some people even like the boosterless setups and I personally think that those are the most horrible thing to have...
                      Hi Pazi, which booster exactly you bought? I saw a couple from e92 320d but i guess their master cylinders would differ as well.
                      And do you think this will work in RHD?
                      Thanks
                      • pazi88
                        • Sep 2015
                        • 584
                        #101
                        Thanks
                        Don't know about RHD. But I think mine was from 320D. The same booster and master is used in high variety of cars: https://www.realoem.com/bmw/enUS/par...&q=34336785664
                        So there are plenty of cars to choose the booster from. All same.
                        The master in these is 25.4/22.2 mm. Only the 316-318 came with different master which is 23.81/22.2 mm. Don't know which master works better. The smaller one may be better match to e30 stock brakes because of the size relation between front and back circuits is closer to e30 original. But I will use e38 4-pot brembos which came with 25.4 master also.
                        • yasnick.ramputty
                          • Jan 2015
                          • 9
                          #102
                          Thank you for your reply. Appreciate a lot.
                          • pirate323i
                            • Apr 2008
                            • 2
                            #103
                            Great info guys!
                            My M52 is running a single stage Audi brake booster, but this may be a good upgrade (my pedal is pretty hard).
                            Sent from my SM-G930F using Tapatalk
                            • Noshow20x96
                              • Dec 2013
                              • 144
                              #104
                              Originally posted by pirate323i
                              Great info guys!
                              It’s a amazing upgrade. Thanks for reading.
                              Onwer of
                              • Noshow20x96
                                • Dec 2013
                                • 144
                                #105
                                Update update update. Take a look at the first page and see the update, I put down everything that you need to do the e9x booster swap
                                Thank you.
                                Onwer of
