M50 swap that will blow your mind.
  • Staszek
    • 2533
    #61
    Originally posted by pazi88
    Yes the tabs are for clutch line. Cut one open and put the stock clutch line to it.
    I already bought mine, but also ln m52 the resevoir is on way. I'm trying to find fine that is not remote one.
    Will the M52 reservoir fit directly on the E90 master? What other reservoirs are options. The ones that come with the E9X boosters are tilted.
    • Noshow20x96
      • Dec 2013
      • 144
      #62
      I don’t think it’s a big deal. The shop That I do some work in, they did it and just raise the reservoir upwards to clear the tps on the throttle body. You can probably find plastic fittings at your local auto parts store, put them in the master cylinder and then run soft lines to the reservoir
      Sent from my iPhone using Tapatalk Pro
      Onwer of
      1987 e30 325e soon to be s50
      1991 e30 318i four door
      1994 e34 530i 5speed
      05 e53 X5 4.4i fully loaded
      • E30335i
        • Feb 2014
        • 1035
        #63
        Going to be doing this very soon, but on s54.
        • MWC
          • Jul 2018
          • 21
          #64
          Is this booster going to work the S54? Isn't there even less clearance there than with an M50 based engine?
          • E30335i
            • Feb 2014
            • 1035
            #65
            Still prepared to do small cut out on the intake box but it’s an experiment, if not, gonna do hydro boost using e28 535i/m5.
            • MWC
              • Jul 2018
              • 21
              #66
              Nice I've been doing a lot of research about what the best way to do it is. I'm going to be repainting the car when I do mine so modifying the firewall in some way is an option too. I wonder if it would be possible to move the booster farther back into the car if it doesn't fit.
              • Noshow20x96
                • Dec 2013
                • 144
                #67
                I have some more made, two are already called for, will be making some more this week.
                The ugly one on the right is the original one that I made by welding to pins together.
                Onwer of
                • dude8383
                  • Jan 2005
                  • 10387
                  #68
                  A word of caution for those that are doing this booster with a BBK up front only... if you plan to track the vehicle you will need to upgrade the rear as well otherwise you'll be going through brake pads like I did.
                  The 25mm master will shift the bias all the way forward on our cars if you don't match up the front calipers with something larger out back.
                  For reference:
                  Switching back to a stock master cylinder cured all of my issues. I have the 280x22 massive kit.
                  • E30_GT
                    • Jun 2012
                    • 48
                    #69
                    Nice set up,thanks for the write up
                    Enviado desde mi SM-G930F mediante Tapatalk
                    • ba114
                      • Sep 2015
                      • 364
                      #70
                      Thanks for quoting the entire post with all the pictures too... :-?
                      RHD OBD2 M50b25 turbo build thread:
                      http://www.r3vlimited.com/board/showthread.php?t=384800
                      • agent
                        Vice Grand Pubaa
                        • 7960
                        #71
                        Fixed that. ^
                        Originally posted by kronus
                        • KIRIEIW
                          • Dec 2012
                          • 3385
                          #72
                          For reference:
                          That’s really good info to know, I plan on ordering a kit from Lee myself in the next month or so. Thanks for the share dude.
                          1992 e34 Touring- S50 Swap
                          1992 325i-S50 Swap (SOLD)
                          1991
                          • moatilliatta
                            • 6151
                            #73
                            Can anybody do a side to side comparison to the E32 735 unit?
                            Will E90 booster fit with an S54?
                            @Zakspeed_US
                            • Staszek
                              • 2533
                              #74
                              Give me a few months and I will let you know. I am putting the E90 unit in with my S54. I still may have to shave the plastic a bit, we will see.
                              • moatilliatta
                                • 6151
                                #75
                                If anything, it looks significantly lighter.
                                @Zakspeed_US
