The comprehensive DOHC engine swap thread.
This is a sticky topic.
  • Brew
    • 3060
    #601
    I ended up using the stock e30 high pressure hose and a e36 318 low pressure line (pump to rack) with a '95 M3 rack, which I believe has the same hose configuration as the Z3 rack.
    '91 318is
    • skatebline
      • Sep 2006
      • 167
      #602
      has anyone put a s50 head on a m50? if so how is it? is it worth doing or no
      • e30tom
        • Mar 2006
        • 116
        #603
        I think the only difference is the cams.
        • E30_pilot
          • Sep 2005
          • 1461
          #604
          Much thanks Brew!
          -Frank
          1987 325is m50nv (schwarz)
          1990 325is (sterling silber)(sold)
          2001 525i
          • colamangr
            • Jul 2006
            • 4
            #605
            E34 compatible???
            Hello!
            Today i bolted the engine with the tranny(both e34) on the subframe. When i raised the subframe with the engine it didn't line up to the bolts it seems that it has to go a little to the back but it doesn't because the tranny touch the firewall protection(that black material)! What should i do? HELP me please....
            Akis
            • DEV0 E30
              • Oct 2004
              • 8893
              #606
              Originally posted by colamangr
              Hello!
              Akis
              Not sure if you've fixed your problem but...
              Are you using E36 engine mount arms?
              Are you using E28 m5 motor mounts or E28 533i mounts (require slight spacer for most people though)
              You need both. If you are trying to use the E34 engine mount arms that is why I'd think it wouldn't line up at all. Also make sure you have the motor mounts aligned correctly:
              • Bimmer335is
                • Jun 2006
                • 146
                #607
                I have a few questions, doing an s50 swap
                1. can you use urethane e28 535i motor mounts?
                2. can you use e30 trani mounts if your using the getrag 260? if so, is it okay to have solid aluminums.
                3. i have a front strut bar, am i okay putting the motor and trani in as one with this there?
                thanks
                • tonytony
                  Knee deep in poopie
                  • Jan 2004
                  • 3498
                  #608
                  1. yes you can
                  2. yes you can, just gotta modify the tranny bracket or custom fab one. I used the 88 e34 mounts. look above it's what it looks like
                  3. i suppose you can if you really wanted to but why? takes like 5minutes max taking off the bar.
                  • BingM3
                    • 863
                    #609
                    For the s50 conversion, from what engine code and year E34 oil pan?
                    Also, part # for the oil sump?
                    Thanks
                    Bing
                    • DEV0 E30
                      • Oct 2004
                      • 8893
                      #610
                      Most info is on the first few pages but:
                      1990/1 -> 1994 M50 Oil Pan from E34
                      http://realoem.com/bmw/showparts.do?...98&hg=11&fg=10
                      01 OIL PAN 1 02/1994 11131740346
                      Oil Pump / Sump Assembly
                      http://realoem.com/bmw/showparts.do?...77&hg=11&fg=30
                      06 SUCTION PIPE 1 11411748150
                      REALOEM.COM is a great resource.
                      • colamangr
                        • Jul 2006
                        • 4
                        #611
                        Hello!
                        I fixed it! It was that protection the black thing. I took it off and now it is ok!
                        Thank you for your answer!
                        • BingM3
                          • 863
                          #612
                          What is the part # for the oil sump in the E34 oilpan, can anyone send the sump pump part link to realoem.com, could not find it....thanks
                          • FredK
                            • 14762
                            #613
                            DEV0 E30 already pointed out the exact part you need. The SUCTION PIPE is synonymous with oil sump / pickup tube. It's part #6 in the supplied link.
                            • Bimmer335is
                              • Jun 2006
                              • 146
                              #614
                              I found an e32 735i brake master cylinder/booster assembly for about $100. Couldn't you just use it, and no modifications for the s50 swap? If not, what are my options. Right now I have an ix booster and master cylinder assembly, what else do I need? Dont I have to swap out the master cylinder for an e28 m5 one or something else? Should I buy the e32 735i bmc/b assembly and combine the two, would that work? Cuz a new e28 m5 bmc is $200 or so.
                              • tonytony
                                Knee deep in poopie
                                • Jan 2004
                                • 3498
                                #615
                                i'm using the ix booster also and the m5 MC, i looked at the MC for the ix and it looks like it'll work as long as it doens't interfere with the intake boot.
