transmission of choice?
  • hoveringuy
    • Dec 2005
    • 2754
    #31
    This is what I'm shooting for... (the 6 speed, not SMG!)
    • Stu
      • 4083
      #32
      Originally posted by rThor432
      Which starter did he use? I think the M20 and M50 starter gears have different offsets? If it's a plug-and-play other than a little grinding, I'm all for that. Let me know as much as you can about his setup (via PM if that's better). I have the opportunity to get rid of the ZF for $800 or so, but I need to act quickly.. Let me know, please and thanks Stu.
      Man, that must have been a buzz bomb.. ha.
      Yeah Mitch's does need it. He wants the UK close ratio though, so he can keep his over-drive. The dogleg with a 3.64 would drive me insane on the highway. My 323i with the 3.23 rear gear was pretty bad. Still about ~250-300 less rpm in 5th than a 260 with a 4.10.
      Hey man I'll let you know about the tranny before the end of the weekend.
      • rThor432
        • Feb 2007
        • 3907
        #33
        ^^Thanks Stu, I appreciate it.
        • bostonbmw
          • Nov 2004
          • 429
          #34
          Originally posted by So Live
          You need to run a new diff though. 3.46 is the super performance one e36 guys run. 3.25 is the stock M3 ratio. Some people run 2.73 but only with extra hp. I like my 3.25.
          All 3.0-liter E36 M3s regardless of engine type have a ZF Type C five-speed manual gearbox with the following ratios: 4.20 (1), 2.49 (2), 1.66 (3), 1.24 (4), 1.00 (5). This is mated to a limited slip differential (25%) with a 3.15:1 final drive.
          The Automatics,GT's and lightweights got a 3.23
          thats from www.bmwmregistry.com
          • rThor432
            • Feb 2007
            • 3907
            #35
            ^Except for the '97 auto, which got a 3.38:1 rear gear.
            • MIKe30
              • Sep 2006
              • 2334
              #36
              I've been searching and can't find it. I thought I read somewhere on here that there was a 5% (or 7%) extra drivetrain loss of power with one tranny over the other.
              anybody have any more info on this?
              • lifeiskaos
                • 1709
                #37
                im slightly confused. i know 240's came on 318's, 260's came on 325's, what about the getrag 250's? or the zf's? what tranny tranny do e34 m50's come with?
                • SpecM
                  • Oct 2005
                  • 4531
                  #38
                  g240s came in e30 318i
                  g250s came in e36 325i
                  g260s came in e30 325i
                  zf320s came in e36 m3/328i
                  iirc the e34 m50 had g250s as well
                  1989 cirrisblau-metallic 325i
                  • rThor432
                    • Feb 2007
                    • 3907
                    #39
                    That sounds right.
                    • BenM
                      • 2184
                      #40
                      '92 525i had the ZF310 AFAIK.
                      Originally posted by BillBrasky
                      E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
                      1991 318i Alpine II - S50/5-lug swapped - track car
                      1989 325i Cirrusblau - Daily
                      1970 2500 - Malaga over Grey Cloth
                      2012 F350 6.7PSD
                      • Kerrath
                        • Jun 2008
                        • 577
                        #41
                        Originally posted by Stu
                        The M20 is tilted 10-degrees to the left compared to an M50. Therefore, when you mate an M20 (260) transmission to an M50, the tranny sits 10* to the right. This is not a problem. You need to fab up a tranny brace and cut/rotate 10-degrees/weld the selector rod.
                        It sounds like your friend didn't do this, and the console is getting in the way of grabbing 5th gear. :)
                        I get the selector rod, makes sense. In an '86, it uses a shift plate which bolts up to two points on the tranny which means the pivot for the shifter is taken off center too. Got ideas on how to re-center it?
                        • SpecM
                          • Oct 2005
                          • 4531
                          #42
                          got vice-grips?
                          • MDryVur
                            • 395
                            #43
                            Originally posted by hoveringuy
                            I run the 260 and am happy with it. I didn't choose it; it chose me..
                            awsome..:up:
                            • Kerrath
                              • Jun 2008
                              • 577
                              #44
                              got vice-grips?
                              So it's a job for torsion, just bend it around?
                              • MIKe30
                                • Sep 2006
                                • 2334
                                #45
                                anybody?
