m50 in, driveshaft not straight
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827 -
Yep, that's how mine are.
Now the fucker won't start. It cranks and cranks and cranks, and gets fuel pressure, but no spark. Main relay has power.
Any common things to check?
I have 537 ohms on my CPS... I thought that was the m20 expected rating, and m50 was 1280? The engine ran great before I removed it a few months ago from the 525i...
I also hooked pin 20 of x20 up to my wire going to the green tach connector, and the tach doesn't jump at all when I try to crank it over.Comment
Crankshaft position/rpm sensor should be 1280 ohms +/- 10% according to e36 bentley.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
Apparently, the Bentley is wrong, and I should be looking for 540 +/- 10.
So what things should I be looking for, with a no spark condition, with power at the main relay? I know NOTHING about m50's or their ignition systems.
My wiring is good, I just went through and did a continuity test across the harness, and double checked the pin-outs. I have my c104 hooked up (pin 1 to x20 14, pin 3 to x20 pin 24). x20 pin 20 goes to the wire on the green connector on the back of the cluster.
All sensors are hooked up on the engine harness (I never disconnected any of them). I have a ground attached to the drivers side engine arm, the coil pack ground on the rear of the valve cover, the single wire at the front of the engine, the two wires near the ECU grounded, the power wire near the ECU hooked up, the ECU is grounded.
I'm getting fuel pressure, I know because I left a line loose and it sprayed everywhere. The line from the pump is on the bottom silver hard line. I switched them just for shits and giggles, no change.Comment
Check the resistance on the Cam sensor as well, but it sounds like a bad Crank sensor. I forget if the cam is around 540ohms or 1280ohms.
Check for anything else that may be disconnected like the MAF, TPS, or Intake temp sensor.1991 318i Alpine II - S50/5-lug swapped - track carOriginally posted by BillBraskyE36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
1989 325i Cirrusblau - Daily
1970 2500 - Malaga over Grey Cloth
2012 F350 6.7PSDComment
Here is a question...
Why does my car have two throttle bodys? It's got the main one that I see all m50's have, then there is like a second throttle body housing in front of it, with another flap, actuated by another lever (I'm guessing cruise control)? The second one is always open, and when you pull the lever, it closes. There is a sensor on the top of that second one, a 3 pin sensor, looks like a TPS. There's no connector on my harness for it, so I assume it's cruise control. Could this be causing any issues?Comment
Why does it sound like a bad crank sensor, if it tested out ok?
It's also weird a sensor would go bad in the short time it took to pull the motor from the e34 and put it in an e30. But, anything is possible...Comment
From what you describe, I believe that is the ASC+T. Maybe someone can tell you for sure. I think it can be deleted easily.Here is a question...
I think I am going to rescind my thought of it being a bad CPS. If it wasn't operating properly, then you wouldn't be getting fuel. Make sure you check the cam sensor as well. Maybe a large vacuum leak?1991 318i Alpine II - S50/5-lug swapped - track carOriginally posted by BillBraskyE36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
Hmmm... I'll see if I can confirm in another manual since you are saying Bentley is wrong...
Two TB flaps, sounds like you are you using an OBD2 tb?Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
You are right, this is what I have...
Is this going to cause an issue not being hooked up? I'll deal with removing that stuff after I get the damn thing running if I can...Comment
The only one that fits an e30....
As I said, everything minus the engine has worked fine in the car for years... nothing changed.Comment
