m50 in, driveshaft not straight
  • JGood
    • Jan 2004
    • 7959
    #31
    Originally posted by RobertK
    Was your car originally an automatic car? Do you have the reverse switch wire hooked up?
    Yes it was, but it started fine for the past 3-4 years since I did the swap. Also, without that hooked up, it won't even crank.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • SpecM
      • Oct 2005
      • 4531
      #32
      maybe bent subframe(s)... refering to your origianal problem...
      1989 cirrisblau-metallic 325i
      • JGood
        • Jan 2004
        • 7959
        #33
        I think it's weird the CSB/Guibo/u-joints have help up fine for so long with everything tweaked that far if that's the case.
        • 1991 e30 bmw 318is
          • 523
          #34
          so what was the problem in the end with the misalignment? i'm having a similar problem. i think i need to flip my csb.....
          91 e30 318is M50 SOLD
          http://www.r3vlimited.com/board/showthread.php?t=149570
          92 325 vert project
          http://www.r3vlimited.com/board/showthread.php?t=341370
          • JGood
            • Jan 2004
            • 7959
            #35
            My driveshaft is angled like a son of a bitch, but it works great (I think 3k miles or so now...).
            I'll report back when my guibo and CSB self destruct and put the driveshaft through the floorboard.
            I never touched the driveshaft, so if my CSB needs flipped then there must have been lawn gnomes coming in at night messing with my stuff.
            Seriously though, nothing is 'normal' on my swap. The shit is crooked, the rad hoses don't fit, etc... Nothing fits right. I think my chassis is different or I accidentally put in an s54 or something.
            • asubimmer
              • 6482
              #36
              mine was from and auto and I didn't hook up the reverse switch. Everything works perfect.
              • 318isbmw
                • Nov 2005
                • 2843
                #37
                Did the same with mine also.
                • Beej '86 325es
                  • 2639
                  #38
                  I had a hell of a time getting my driveshaft and tranny straight as well. It's still not perfect, but straighter than what you're showing in the picture. I ended up slotting the outer holes in the subframe as far as I could and that helped a little. I used a straight edge butted against the crank pulley and tried to line in up with the front frame as best as I could. It made getting the shifter lined up properly really difficult. I'm hoping that once it's been driven for a while things might work their way into the positions they need to be in and I can loosen and retighten the mounts.
                  Do you notice any drivetrain vibration with your current setup?
                  -Brandon
                  '86 325es S50
                  '12 VW GTI Autobahn DSG
                  '03 540i M-Sport (sold)
                  '08 Jeep SRT-8 (sold)
                  For sale:
                  S50 TMS chip for Schricks
                  • JGood
                    • Jan 2004
                    • 7959
                    #39
                    I ended up slotting my engine mount arms instead. I think it helped a little.
                    I do have a very slight vibration in the bottom of 2nd gear at very low RPM's, but who knows what that's from. I had a bad vibration before the swap due to a bad guibo. I've had the car torn apart so many times recently it's hard to tell what is causing what. For all I know, the driveshaft could be out of balance.
