Aftermarket Headers
  • JGood
    • Jan 2004
    • 7959
    Originally posted by evil_twin
    Actually no, it's up higher on the header. Thanks for being a douche. kkthxbi
    He may have a point. Stress one end, and the other end could still crack, it all depends where it puts load. Headers are not meant to flex at all. Maybe you could take a few pics of your setup?
    I didn't get my exhaust done yet, I still have open ebay headers, and they look dangerously low. I'm not sure how it's going to turn out...
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • dpgrand
      • 179
      It doesn't matter where the break happens, they will break at there weakest point, which it seems is up higher in your case.
      • evil_twin
        • Nov 2007
        • 2965
        No I understand where it will break at the weakest point, but it broke at the welds under my heat wrap. It could be from my bracket, but I don't think it is because where my headers meet they have a slip on flange that makes the pipe 1 3" pipe. I took a look at my headers and I noticed that it wasn't the headers that were hanging low, but the slip on flanged that was hanging low. So When I pushed the flange up it would go up and stay up. The flange just had too much play so I made a bracket to hook onto that flange that would pull it up. Either way, it looks like I am getting a new header/exhaust set up and running some flex pipes so I can actually have a bit more play. Sound like a good idea?
        Paypal: vdang5@gmail.com
        Delta Auto Care
        2875-C Towerview Road
        Herndon, VA
        703.435.1375
        My Feedback Thread: Evil_Twin
        • evil_twin
          • Nov 2007
          • 2965
          Originally posted by golde30
          i have neither of those.... the ones i had were 2 piece, kinda a hybrid between the 2 you posted there.
          Where is your o2 reading from?
          Delta Auto Care
          Herndon, VA
          703.435.1375
          • dpgrand
            • 179
            you can see the bungs where the three pipes meet in each header.
            • evil_twin
              • Nov 2007
              • 2965
              Yah, but I'm OBD1, so I only need 1 bung... And I would like to have it where the 2 pipes meet. Or atleast thats the set up I'm running on my car right now.
              Delta Auto Care
              Herndon, VA
              703.435.1375
              • dpgrand
                • 179
                Won't that bung be too far from the engine to get an accurate reading?
                • evil_twin
                  • Nov 2007
                  • 2965
                  hmmm, never thought of it like that. maybe I will have to pull it up to either bank 1 or bank 2.
                  Delta Auto Care
                  Herndon, VA
                  703.435.1375
                  • Uber E30
                    • 1409
                    AKAIK you want the sensor to be where the 2 pipes meet so you can get a reading from from all 6 cylinders w/ OBDI.
                    -Alex
                    • evil_twin
                      • Nov 2007
                      • 2965
                      AFAIK you mean? AKIAK? I dont understand.
                      But yes, I was thinking that you want the readings from all the cylinders, not just 1.
                      Delta Auto Care
                      Herndon, VA
                      703.435.1375
                      • evil_twin
                        • Nov 2007
                        • 2965
                        Anybody ever use these headers?
                        http://cgi.ebay.com/ebaymotors/92-98...mZ360102427184
                        Delta Auto Care
                        Herndon, VA
                        703.435.1375
                        • JeffRR
                          • 277
                          Those look like the same type that I bought, just through a different distribuitor.
                          I had some massaging on the header and the engine mounting arm to get everything to clear. So far so good, can't beat the price.
                          • Kerrath
                            • Jun 2008
                            • 577
                            Yeah, they look like the ones I got which look like the ones you got. Mine are a pretty big pita though because the O2 sensor bungs are in shittarded places. One will hit the other header and the other will jam into the firewall. I'm going to have to get a bung added elsewhere. It shouldn't be a big deal going a couple feet farther back though. Stock position for the bung on E34 and E36 is at the y-pipe just before the cat.
                            http://cgi.ebay.com/ebaymotors/ws/eB...m=230299468596
                            Those are my headers. See the resemblance?
                            • evil_twin
                              • Nov 2007
                              • 2965
                              ordered :)
                              Delta Auto Care
                              Herndon, VA
                              703.435.1375
                              • JGood
                                • Jan 2004
                                • 7959
                                That still pisses me off. It's retarded as all hell.
                                To top it off, I never put a crush washer on the bolt that goes into the bung. So 3 weeks after I finished my swap, the bolt falls out on the highway. I go from having a nice quiet daily driver to having an open header top fuel dragster. To top it off, You can't install the bolt without removing all the heat shielding on the firewall, because it's so damn close. What the fuck. It took me 2 hours to grind down the bolt and pound in the heat shielding to get the bolt installed, and spin it 1/64 of a turn with the wrench with the 2" of clearance you are given. Man that shit still has me pissed off.
                                BEFORE INSTALLING THE HEADERS, PUT CRUSH WASHERS ON THOSE BOLTS.
