In the exhaust bungs you mean? What about a dab of loctite?
Aftermarket Headers
Paypal: vdang5@gmail.com
Delta Auto Care
2875-C Towerview Road
Herndon, VA
703.435.1375
My Feedback Thread: Evil_Twin -
Oh dear god. I did not know they were prone to fall out. >:[That still pisses me off. It's retarded as all hell.
To top it off, I never put a crush washer on the bolt that goes into the bung. So 3 weeks after I finished my swap, the bolt falls out on the highway. I go from having a nice quiet daily driver to having an open header top fuel dragster. To top it off, You can't install the bolt without removing all the heat shielding on the firewall, because it's so damn close. What the fuck. It took me 2 hours to grind down the bolt and pound in the heat shielding to get the bolt installed, and spin it 1/64 of a turn with the wrench with the 2" of clearance you are given. Man that shit still has me pissed off.
BEFORE INSTALLING THE HEADERS, PUT CRUSH WASHERS ON THOSE BOLTS.
I guess I'll have to see how much the car gods like me.
Those headers in general though... fucking poor design. I recommend paying more for the well thought out ones. The amount of time you have to spend screwing around with the kind I got is not worth it at all.
Which headers did you get Evil Twin? The ones you had a link to?Comment
Well if the header wrap covers the bolts and is tight, you should be fine.
It's a hit and miss thing. One of mine fell out, the other was so tight I had trouble loosening it. And I tightened them both prior to this mess, basically as tight as I could get them.Comment
Delta Auto Care
Herndon, VA
703.435.1375
My Feedback Thread: Evil_TwinComment
Alright... So where do I get this crush washer from?I got a fender roller now! LMK if you need me to roll your fenders or want to rent the tool from me locally.
Delta Auto Care
Herndon, VA
703.435.1375
any local auto store...
I had these headers...sounded raspy. I was not happy with them. I am running stock obdII m3 from the headers to the tips and could not be happier.www.classicdaily.net
1970 m42 swapped 2002
1985 LS1/T56 Swapped e28 (557e)
www.blunttech.com - For all your parts needs
Follow me on Instagram for constant build updates @classicdaily
https://www.facebook.com/ClassicDailyLLCComment
It's an 18mm crush washer. Auto parts stores, hardware stores, or just google "crush washer" and pick a place to order it from. It's like buying any other washer or nut or bolt. It just has a special shape to it to help seal better and it just so happens that it holds the bolt in place better as well.
And just an FYI if anyone loses one of the bolts: It's a standard 18x1.5 thread used on most O2 sensor and spark plugs. Not the easiest bolt to come across...Comment
I forgot about that, I didn't use the bungs that came on the headers. I asked the fabricator that did the rest of the exhaust to put a pair of bungs in on the straight section where it bends underneath the fire-wall.Comment
Mr. Good, M18x1.5 bolts are commonplace at auto parts stores as that is the size of a Toyota drain oil pan drain plug.-OVULATOR (as named by jflip2002)
Past Cars: Schwarz 1990 325i-2 (crashed), Calypsorot 1991 325i-2 Sport (rear ended)
Now: Blake-stitched mediocrity :(Comment
Ahh good call... I guess my mistake was calling around and asking for a 18x1.5 instead of just going there and looking. Can't trust high school dropouts working at autoparts stores...Comment
Dude! I am having this same issue right now!! the O2 sensor won't go on header 1-2-3 because fuckin' header 4-5-6 runs into it!! Where did they come up with the locations for these bungs!?Yeah, they look like the ones I got which look like the ones you got. Mine are a pretty big pita though because the O2 sensor bungs are in shittarded places. One will hit the other header and the other will jam into the firewall. I'm going to have to get a bung added elsewhere. It shouldn't be a big deal going a couple feet farther back though. Stock position for the bung on E34 and E36 is at the y-pipe just before the cat.
Those are my headers. See the resemblance?
Same ones I have, they look low but my car is stock height for now so I can't tell.
Same problem, I just added a bung after the headers before the cat.1985 325e 2.8 Turbo VEMSComment
