E36 flywheels
  • e30s52
    • Oct 2007
    • 5235
    /\ what hp rating are they good till?
    www.gutenparts.com
    • m3boost
      • Oct 2005
      • 110
      Originally posted by DaN
      I have this 16lb single mass flywheel, purchased on ebay. It fits perfect, and its about 9lbs lighter than the dual mass. Its a good comprimise between stock, and alum race flywheels.
      http://cgi.ebay.com/ebaymotors/F1-RA...mZ400002009049
      I have this flywheel still in box and I'll let it go for 150.00. I bought the whole kit but decided to stay with the stock flywheel cause was going turbo..
      88 e30/s50 gt35r turbo m3
      96 gt4094r turbo m3
      452 rwhp, 455 rwtq at 14 psi 91 octane
      681 rwhp, 684 rwtq at 25 psi E65
      • Jean
        • 18228
        PM sent
        • Jean
          • 18228
          No problems with the install, fits with no issue of course only with the intended application. S50/zf.
          You will get some trans rattle. My zf uses atf. I just swapped to redline MT90 and the noise is gone.
          Cool. I have a ZF as well, and it came with ATF sticker on it. I take it this flywheel should work just fine with m52 as well or I wonder if it's somehow specific to s50 only?
            • 37834
            It's a stock replacement.
            Grover Beach, California
            BimmerHeads.com
            • evil_twin
              • Nov 2007
              • 2965
              I have this flywheel with their 6puck clutch and pressure plate set up. I love it! My friend has it in his e36 m3 and loves it also. When you have this set up, BE SURE to install the clutch disc correctly. This is installed 'opposite' of how the OE clutch came out.
              Paypal: vdang5@gmail.com
              Delta Auto Care
              2875-C Towerview Road
              Herndon, VA
              703.435.1375
              My Feedback Thread: Evil_Twin
              • DaN
                • 1265
                Are you sure? The clutch disc is made with a flywheel side, and trans side. And are usually labeled. I didnt install anything different than stock. And usually if you do, the results are not desirable.
                • evil_twin
                  • Nov 2007
                  • 2965
                  Well, since its a lighter weight flywheel and a single instead of a dual mass, thats how they have you install it. If I remember correctly when we installed it on the M3, we had it incorrect, and it was a B!TCH to remove the transmission after that. And that was installed with the hat of the disc facing the pressure plate. If you research on bimmerforums there have been numerous people doing the same thing we did, and some of them actually bent their input shaft removing the transmission.
                  But I installed it correct, and I love the set up on my m52/zf e30.
                  Delta Auto Care
                  Herndon, VA
                  703.435.1375
                  • e30polak
                    • 6136
                    I got the Fidanza Flywheels from Gripforce, with a sachs heavy duty clutch kit. The flywheel is 13lbs, and only a little over $100 then the 16lb F1 Racing Flywheel. Works great, but I do get some chatter letting off in 4th and 5th.
                    http://cgi.ebay.com/ebaymotors/FIDAN...mZ390002052671
                    INSTAGRAM: @UNDR8D_EMPIRE
                    • dpgrand
                      • 179
                      Is anyone running the UUC lightweight flywheel? They make a stage 1 and a stage 2.
                      • golde30
                        • 11464
                        i think this is the same one i am running on my s50 swap. i have this flywheel, with oe sachs clutch kit for s50, and running the s50 starter. i am using my stock getrag260 though. my clutch setup feels really good, no problems at all so far.
                        IG: @Baye30
                        • hugh jass
                          • 2220
                          i've got the uuc stage 1 flywheel and e34 m5 clutch on my obd1 s52. its awesome. engine spins up really nicely.
                          ______________________
                          ex-Chief Operating Officer
                          Blunt Tech Industries
                          West Coast and Pacific Rim
                          • dpgrand
                            • 179
                            Awesome. This is the setup that I have been eying.
