Non-OEM oil cooler setup
  • erik325i
    • Jan 2005
    • 3567
    #46
    Originally posted by dude8383
    Noob alert. What do you mean by the thermostat of the factory cooler?
    Does the oil cooler rely on a thermostat to circulate oil at a given time?
    Also, how are you guys mounting the coolers?
    Yes, the stock setup uses an oil thermostat so that it only circulates oil to the cooler once it has reached a certain temp.
    Erik
    • dude8383
      • Jan 2005
      • 10387
      #47
      Erik
      Thanks!
      So what does one do if they don't go with the factory setup?
      • dude8383
        • Jan 2005
        • 10387
        #48
        Originally posted by hugh jass
        i ended up using the euro e46 m3 oil filter housing with the turner AN10 adapter and had someone weld on male AN10 fitting on the stock oil cooler. looks factory except for the big AN10 lines in the engine bay.
        I just realized or rather Patrick realized that the E46 housing has the same P/N as the euro housing.
        Just wanted to throw that in here.
        • dude8383
          • Jan 2005
          • 10387
          #49
          Anyone ever heard of Fluidyne oil coolers?
          I'm looking at their largest one: DB-30130
          I'm also waiting for Patrick to get me a quote for the Earl's 25 row oil cooler.
          • mitch500
            • Jan 2006
            • 1092
            #50
            http://www.millerperformancecars.com...category_id=11
            price is in canadian dollars.
            1988 e30 alpine white vert 5speed
            1987 e30 325 eta
            1983 e28 533
            2001 x5 4.4l
            1997 e36 M3 Alpine white 5speed
            1991 Jeep XJ I6 4.0
            • Nick12908
              • 30
              #51
              I have most the same questions as dude8383.. Anyone have any advice for us?
              Nick
                • 37834
                #52
                I did buy the IE oil filter cap adapter but have not decided on what cooler I want to run yet.
                Soon!
                Grover Beach, California
                BimmerHeads.com
                • dude8383
                  • Jan 2005
                  • 10387
                  #53
                  Soon!
                  i will likely order:
                  My friend has AN fittings and lines so I will be ordering stuff that will fit w/e he can give me.
                  I just purchased the IE cap from Patrick :)
                  • dude8383
                    • Jan 2005
                    • 10387
                    #54
                    Bringing this back up, what's the minimum amount of row's an oil cooler for this particular application?
                    I already purchased an Earl's 25 row oil cooler but I have NO idea where the hell I'm going to mount it. I have no room in front because I have an auxiliary fan...This 10 row would fit just ahead of it though. Any recommendations? I'm going to get my lazy ass to install the oil cooler this summer.
                    • Fusion
                      • Nov 2009
                      • 3659
                      #55
                      What do you guys think about an M5 E34 oil cooler?
                      I have the chance to pick one up pretty cheap. It's not beat up or anything.
                      • Fusion
                        • Nov 2009
                        • 3659
                        #56
                        How beneficial do you guys think an oil cooler is for a N/A motor especially during track use?
                        Is it wasy to fit an S38 cooler in there and where is the best place to mount it?
                        • aznbo187
                          • Mar 2008
                          • 223
                          #57
                          Did you ever go with this? Do you think it would be too big or would fit behind the kidney grills?
                          I'm currently also looking for a plate-style cooler that will be easy to mount up.
                          • dude8383
                            • Jan 2005
                            • 10387
                            #58
                            Hey, actually I haven't mounted mine yet.
                            I will most likely go with my Earl's oil cooler though...I have two:
                            Free Shipping - Earl's Performance Temp-A-Cure Fluid Coolers with qualifying orders of $109. Shop Fluid Coolers at Summit Racing.
                            Going to mount it soon though, just gotta come up with a bracket and placement. I have an aux fan on the condenser side and putting the oil cooler in front of it might not be too efficient. Might put it somewhere behind the valance.
                            • bejbis
                              • Dec 2008
                              • 596
                              #59
                              I'm running the stock e30 oil cooler and just made some custom lines to work with the euro s50 oil filter housing. I really don't understand why you would bother changing the actual cooler for a larger one or an aftermarket one, the stock one is more than adequate for most people, is in a good location, and requires no modification to get it to mount.
                              As far as how beneficial it is to have a cooler on these motors. I really doubt its a huge benefit on a N/A car. I would not of bothered with a oil cooler if the motor i bought didn't already come with the oil filter housing.
                              Here is a link that shows what i did to make the stock cooler work with the euro filter housing.
                              -Dan
                              • TurboFox93
                                • 173
                                #60
                                Pictures of setups?
