24v sales thread
  • Fidhle007
    I can fly, motherfucker
    • Oct 2005
    • 7209
    #46
    Originally posted by MDryVur
    can you explain the zero caster?
    Not having any caster. Which is why IXs handle like trucks and why you're going to wrap yours around a pole with an S52.
    '89 325is S50 Track Montser
    '04 X5 Daily/Tow Vehicle
    http://www.avarestoration.com
    http://www.myspace.com/brendanfiddle
    Click here if you want to be my zombie slave...
    http://www.youtube.com/user/Fidhle007
    • MDryVur
      • 395
      #47
      ^ ohh ok.. what ill do then is put an m20 in there drive around and see how it handles and drives. i still have to make the tranny mounts though.
      Thanks for your opinions and thoughts Fidhle007 its really appreciated. i
      • Fidhle007
        • Oct 2005
        • 7209
        #48
        HONESTLY... i can see what your saying but the only thing i can tell you is that you have to see it for yourself. i think ill get an m20 motor and tranny stick it in let the weight set on the frame and wheels to see what happens. and work it from there. but from what i see and to my knowledge i think it will be for the better.
        I'VE SEEN IT FOR MYSELF. I own a swapped IS and a lightly modified IX and I am a tech and have seen hundreds of customer's cars as well as my own. The IX was designed with a different strut tower configuration then the e/i cars in order to account for the steering/drive issue on the front wheels. The upper strut mounts were moved forwards by quite a bit to eliminate caster, thereby reducing steering effort which would have been increased by the front drive. This makes them handle like trucks but the powered front wheels compensate for that a little, the instant you remove power however, you now have a car with zero caster and no front drive to account for that. Add more horsepower to that equation and you have another car around a signpost.
        • MDryVur
          • 395
          #49
          if it helps im going to have negative cambers in the front from what it looks like ill keep you posted and let you know what happens if your curious .. which i think you are .. cuz you wont drop it. lol
          • MDryVur
            • 395
            #50
            your right the subframe from the ix was a bit forward from the i ... however the mounting positions were still there for the i subfame, that is why i was able to put that in with no effort.
            • Fidhle007
              • Oct 2005
              • 7209
              #51
              If you want a swapped car, or any rwd E30, you should use a rwd platform. The IX was designed specifically as an AWD car and converting it and adding power isn't going to be fun and could potentially be dangerous on the street. Caster is what centers the wheel when you let go of it and provides valuable steering feedback. To not have that on a 240hp, sub-3000lbs car will be scary.
              I tried to tell you this months ago but you got all angry and insisted on "being different" despite the fact that we're all just trying to help out. Now if you want to swap an S5x into an IX and keep the AWD system, THAT would be cool. I know a guy who's in process, I'll have to see how that turns out.
              • Fidhle007
                • Oct 2005
                • 7209
                #52
                Camber and caster are different. Do some reading on suspension geometry.
                The positioning of the subframe in the body is just to clear the front axles and have a mounting place for the motor. The issue is with the strut towers. The subframe mounts to the frame rails which are the same on all the bodies but the strut towers are IX specific.
                • MDryVur
                  • 395
                  #53
                  actually both are different.. if you check rail youll see what i mean. i had to move the subframe back from the original mounting position.
                  • MDryVur
                    • 395
                    #54
                    yeah sorry about that . :neutral:
                      • 34834
                      #55
                      while we are on the subject, is it true about the fronts?
                      functionality wise i know dumping an IX would be pointless, aside from a nasty track beast. But i think it would look pretty sick.
                      lowered though seems it would still function better then just making it RWD ;)
                      no, but people let the boots go bad for 30,000 miles and then have to buy a $500 CV shaft from the dealer instead of a $20 boot kit.
                      there are a lot more options than just H&R sports..
                      if you want to know how an ix handles when converted to RWD, ask Ryan G. It was bad enough that he pulled the 24v motor and converted it back to stock..
                      • Fidhle007
                        • Oct 2005
                        • 7209
                        #56
                        What's different?
                          • 34834
                          #57
                          the only difference in the frame rails is the mounting holes for the AWD subframe. It still has the holes for the regular steel subframe though.
                          • Fidhle007
                            • Oct 2005
                            • 7209
                            #58
                            So a driveline vibration under load = deaded CV joint up front maybe?
                              • 34834
                              #59
                              or a dead flex disk (there are 3), bad rear u-joints, could be a CV joint but those usually click/clunk when you turn the wheel.
                              My hunch is an out of balance rear driveshaft or bad flex disks. the CV shafts are too small to really cause a vibration unless they were very damaged, but then they would probably just explode by that point.
                              • MDryVur
                                • 395
                                #60
                                how do i get in contact with him.
