PWM fan or E30 fan with stock wiring?
  • NvE30
    • Apr 2019
    • 48
    Is it better to use a PWM electric fan or just use stock e30 fan with stock wiring with Hi/Lo speed relays?
  • R3Z3N
    • Jan 2011
    • 3056
    Advantage to the PWM fan is threefold: better heat management dependent on speed and temperature, less shock load the the system as the fan switches on and off, more power at wide open throttle as the fan will turn off to not draw alternator power.
    Here is the full version of how the PWM fan works
    • Northern
      I like cupcakes & sh!tboxes
      • 5284
      I think this is the big one for me. I use the Merc switch with aux fan wiring, and there's a definite idle dip/light dimming when the fan kicks in.
      Not really a problem, but it's something that's recently started to annoy me more.
      Originally posted by priapism
      Originally posted by shameson
      • TobyB
        • 5296
        The only real down side to the E46 system is that the pwm fan's a known weak spot.
        It's certainly very elegant.
        t
          • 34847
          You can control any fan with PWM - including the stock E30 fan. the PWM module can be removed from any E46 fan, and you can wire that to whatever fan you want to use.
          Personally, I got tired of the fan switch because it switched on/off constantly and was very noticeable. I'd definitely do PWM if I had the choice.
          • ba114
            • Sep 2015
            • 364
            Clutch fan FTW
            RHD OBD2 M50b25 turbo build thread:
            http://www.r3vlimited.com/board/showthread.php?t=384800
            • R3Z3N
              • Jan 2011
              • 3056
              Originally posted by ba114
              Clutch fan FTW
              No clutch fan for S54 swaps...... not enough room.
                • 34847
                Or N52s, which never had a clutch fan to begin with.
                I mean, the clutch fan definitely cost my M20 some power. and I had plans to put the electric fan back in with a PWM controller to avoid the harsh on/off switching... but, it's slow either way, so I just never bothered.
