Starting my M54B30 swap...
  • Elysian
    • 674
    Got one picture for now... I didn't see a better place to put this thread, and this isn't the place to tell me I what I should be doing swap wise, I'm set on the M54 swap, and I'll be swapping as much of the electronics from my donor 01 330ci as possible. Right now, I'm at the stripping down stages, taking it to the bare shell. I should be pulling the M54+trans fairly soon. Going to be running it on the stock ECU.
    This is the car:
    Enough people have already told me how shitty it is, I don't care, keep it to yourself.
    I've got all the time in the world for this swap(unless I for some reason die), and budget isn't an issue, so I'll be updating this at every stage, but don't expect it to be a quick build... I also plan on doing some body work, that'll also be posted in this thread.
  • bataangpinoy
    • Jul 2008
    • 1636
    awesome. a sleeper! what does the m54 make power/tq wise? i have acess to a 323ci that i can pull stuff off of if this isnt too crazy(as far as wiring goes)
    My feedback:
    http://www.r3vlimited.com/board/showthread.php?t=186328
    http://e30tech.com/forum/showthread.php?t=74911
    Instagram:
    @gears_n_glory
    @functionmotorsports
    • Elysian
      • 674
      323ci would be M52TU, which doesn't make much power at all. I'll be running my M54B30 with headers, it dyno'd at 207rwhp(around 244 crank), can't remember what torque was, I don't have my dyno sheet anymore :(
      • bataangpinoy
        • Jul 2008
        • 1636
        iknow that, but as far as little things like sensors ans stuff.
        My feedback:
        Instagram:
        @gears_n_glory
        • Elysian
          • 674
          Hoveringuy has run an M54 on M50 electronics plus a custom dual vanos board, might look in that direction. I wouldn't know anything about running an M54 on M52TU stuff, if that's what you're asking.
          • Elysian
            • 674
            after consulting with hoveringuy, I've decided to use my getrag 260 in the swap.
            • Elysian
              • 674
              Started pulling apart the 330, I'm going to go pretty basic on this, only use what's necessary to run the engine by itself. Radiator is out, expansion tank, and the ac condensor is disconnected. Need to disconnect the power steering hoses and work on pulling the wiring harness. I'm also considering building a sheet metal dash, I'm not super interested in making this car a daily, I'd like to build a cage, a dash, and patch up the sunroof hole. Also considering lexan for the triangle windows and rear windshield.
              • daniel
                • 6703
                I love the M54B30. It was awesome when I drove hoveringuy's car, and it is currently awesome in my E39 530i. The flat torque curve rocks.
                Good luck on your project!
                http://instagram.com/dslovn.drives
                • nrubenstein
                  • 3148
                  My 323i puts down 184rwhp. :)
                  Cams, headers, 3" exhaust, intake. It made power a lot more easily than I expected. My next plan is to get an M50 manifold on it.
                  2002 BMW M3 Alpinweiß/Black
                  1999 323i GTS2 Alpinweiß
                  1995 M3 Dakargelb/Black
                  - S50B32/S6S420G/3.91
                  1990 325is Brilliantrot/Tan
                  1989 M3 Alpinweiß/Black
                  • lennon
                    • Jun 2008
                    • 1416
                    your 323i has the DISA or whatever variable intake right? i take it that since you want to switch, those manifolds are still considered restrictive compared to the obd1?
                    • hoveringuy
                      • Dec 2005
                      • 2742
                      You could also get the 3.0 litre intake. M50 will flow better than both but you'll leave a lot on the table without DISA unless you live over 4000 rpm.
                      • lennon
                        • Jun 2008
                        • 1416
                        That basically answers my curiousity too. So there's 2 (or more?) different DISA manifolds?
                        • hoveringuy
                          • Dec 2005
                          • 2742
                          Yes, the 2.5 litre has a smaller DISA manifold and it's possible to switch to a 3.0 litre manifold.
                          Where it gets interesting is that all N52's are 3.0 liters. Even the 323 has a 3.0, but the motor is purposely choked with restrictive tuning and a smaller intake.
                          • Elysian
                            • 674
                            Worked on the 330 some today, the engine is almost ready to come out. Need to give it another once over, but I believe the only things connected right now is fuel and the trans stuff/driveshaft. Tomorrow if I have a chance to work on it in the morning it might be fully ready.
                            I'm also interested in possibly, in the future, converting it to OBD I, but I'm not really for sure right now.
                            • jrdeamicis
                              • Nov 2008
                              • 956
                              Don't feel bad about starting with a shitty e30. I built mine on an 84 frame and I couldn't have been happier.
                              Past Car : E30 S50 6 Speed 5 Lug 3.73
                              Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                              ___________________________________________
                              BNB Designs
                              Engine Swaps, Fabrication, Innovation, General Repair
                              Richmond CA
                              Julian 848-248-8029
