s50 vs m54 vs m50 vs m30 dyno
  • e30polak
    • 6136
    Originally posted by gregslow318i
    for comparison dinan chiped m60b40 same dyno different day
    That must be a blast in an e30! :twisted:
    Originally posted by JGood
    Does that m50 cut out at 6200 RPM's and basically stop accelerating? My buddy had a problem with his m50 where the ground wire that comes from the injection wire harness, out to the vanos bolt, was broke, and the engine cut out at around 6200. Felt like a rev limiter in a way.
    Or it could be like my old car - was an auto to manual swap, and the speed sensor was never hooked up. After getting rid of the TMS chip with the speed sensor delete, I got fuel cut at 6200.
    INSTAGRAM: @UNDR8D_EMPIRE
    • hoveringuy
      • Dec 2005
      • 2706
      Originally posted by JJe30
      It kept reving to red line (7k) it just dropped in power. Guy at the dyno though maybe fuel issue. So I'm going to start with checking fuel filter and pump and go from there when I get home.
      I thought it was too quick of a drop for it to be a fuel issue.
      • JGood
        • Jan 2004
        • 7959
        I'm not expert, but I'd agree with this. It looks like at 6249 it's making 190whp, and at 6250 it's making 155whp. It it was a fuel pressure issue, I'd think it would be more gradual. It might be fuel being cut, but I think it's a controlled cut, not a pressure issue...
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • JJe30
          • 2044
          Could it be a tune issue? Guy at the dyno said it might be but he highly doubted it.
          • balooshinakus
            • 511
            It could be. Is your speed sender hookup up to the ECU? If it isn't that is definitely your problem.
            • JJe30
              • 2044
              I'm not sure. I had gregslow do my harness. I'll have to check into that.
              • gregslow318i
                • Sep 2007
                • 1918
                what year is your car? is the dme chipped?
                looking for a e30m50 swap harness adapter pm me $150 shipped
                email nitroman12@gmail.com
                • JJe30
                  • 2044
                  It's an 85. DME has TRM chip in it
                  • gregslow318i
                    • Sep 2007
                    • 1918
                    I would be willing to bet the chip has a speed control delete if it doesn't I can show you how to add the wire to hook it up but pm matt about the chip first
                    on another note I had a lot of problems with my TRM tunning (driveability and performance) on the old m52 that was in the v8 car before it went v8. but I seem to rememberer my dyno graph also having a "hick up" aswell.
                    I can post the dyno sheets if needed
                    • JJe30
                      • 2044
                      Thanks, I did PM him earlier and asked him what he thought.
                        • 34839
                        why would you do a speed input delete rather than just hooking it up?
                        • matt
                          • 3731
                          Bingo. It does look like that is the problem.
                          Greg, I was willing to work with you to straighten out your car, but you started bashing me on here instead. As far as I know you tried none of our suggestions.
                          If your solution to a motor that isn't running right is to swap in another motor, you don't get to blame the chip.
                          • El Gato Liso
                            • Jun 2008
                            • 44
                            Originally posted by Bimmerman325i
                            Makes the m50 + boltons + cams option much less attractive. Spend S50 money and maybe make stock S50 power if it wasn't running so lean.
                            very unattractive...i had that setup in line.
                            i sourced out an m52 with around 200k on it for 500$, and was going to ODB1 it....but im going to go with the s50 cam setup since i was basically barked at by other e30 junkies,that it will make more power than the m52, and close power to s50.
                              • 34839
                              M52 has more displacement though
                              and it looks like his power would have kept climbing to at least 200whp, which isn't bad for a 2.5l
                              • hoveringuy
                                • Dec 2005
                                • 2706
                                200whp is great for a 2.5l, but I don't think having that power only at 6500 is that useful. The problem is that his torque is down 50ft-lbs across the board.
                                Displacement!
                                BTW, ESS is selling a complete factory ZHP cam kit with gaskets and everything for $299. These are 10.0mm/10.0mm 248/248 vs the 9.7mm/9.0mm 240/244 Intake/Exhaust stock M54 cams I currently have.
                                I think an s50 has 10.2/9.7 252/240, so these would help close the gap on the top end for me.
                                http://www.ecstuning.com/BMW-E46-330...aign=postreply
