S54 advice and considerations
  • Wh33lhop
    • 11705
    #166
    Originally posted by Wanganstyle
    Extra clutches adds MU by doubling surface area; just like a single/double/triple plate tilton for 1,000hp++ supra.
    I get how that is supposed to work but that would require a mating friction surface as well. I was under the impression that you just stack the clutches which would do nothing for surface area and just act as a shim. I guess I was mistaken--which is good, because it would be pretty dumb to do it that way.
    paint sucks
    • Wh33lhop
      • 11705
      #167
      Originally posted by The Dark Side of Will
      Thanks! I was thinking I was going to have to be the ass who points out what Torsen is... ;)
      Like Wanganstyle said, changing the number of clutch disks changes the relationship of locking torque to clamp load on the disks.
      IE, (pulling numbers out of the air) a 45 degree ramp with a 2 plate clutch pack might deliver 200 ftlbs of locking torque at a given driveshaft torque. The Bellville spring might give it 50 ftlbs of locking torque from preload.
      The same ramp with a 4 plate clutch would deliver 400 ftlbs of locking torque at the same driveshaft torque. The same bellville spring in the 4 plate unit would have 100 ftlbs of locking torque from preload, BUT using a softer bellville spring can drop the 4 plate unit back down to 50 ftlbs.
      So the number of disks *DOES* affect the slope of the locking torque vs drive torque curve.
      LJ851 posted while I was writing, but I already knew what a bellville spring is ;)
      Again, I got that in theory, but from how people were talking about building a diff it seems like they were just stacking the clutches one on top of another, which made no sense. A simple misconception is all.
      paint sucks
      • giantkeeper
        • Aug 2009
        • 1416
        #168
        Soo, about those S54's :D
        Always Always go for the reach around if there is an option
        • Wanganstyle
          • 2828
          #169
          as far as S54 news is concerned; currently working on a parallel DME solution to allow for "obd2" port function with S54 and OBD2 non s54 DME......
          s54 port porn.
          silly little fingers are awesome.
          hiding in the woodwork, machine shop was double thumbs up on all the OEM CNC work.
          • Thing30
            • 171
            #170
            Anyone have personal experience with SC Typhoon ECU...
            • VinniE30
              • 2113
              #171
              Would a M42 radiator work OK with the s54? Cooling capacity? Seems like it works just as good as the other radiators with the 24v swaps.
              Zinno '89 <24v swap in progress>
              • e30m3s54turbo
                • Jun 2010
                • 3291
                #172
                VinniE30 m42 should work.
                • VinniE30
                  • 2113
                  #173
                  This would be so cool:
                  All aluminum M42 style radiator with built in reservoir
                  • gobuffs
                    • Dec 2004
                    • 513
                    #174
                    I added a roundy round all aluminum triple pass radiator for $199. Cools better and cheaper than anything you'll find that is specific for BMW and is 1/3 the price.
