Andrew's S54 Swap
  • Andrew325is
    • Jan 2008
    • 1209
    #151
    The part number for the M22 female to -10 AN male adapters is 7007-10-M22 which I originally found in a thread on S14.net. I looked through Brennan's catalog and it looks like this is it: 7007-10-L15-22.
    (http://catalog.brennaninc.com/catalo...7007-10-L15-22).
    I found one here for $13:
    http://www.royalsupply.com/store/pc/...m#.Uaf4XZywXgU.
    Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
    • Andrew325is
      • Jan 2008
      • 1209
      #152
      Here's a place selling them for $11.43: https://www.flowline.net/default.asp...7007-10-L15-22.
      • Andrew325is
        • Jan 2008
        • 1209
        #153
        My original build thread needed some maintenance so I fixed it up. The pictures should all load the correct size now and I added some more swap info. :)
        • ahriley91
          • Jan 2010
          • 451
          #154
          Did you ever get the cruise control working? I've been looking to add it to my swap now. I think the e85 unit will work but am not positive.
          http://www.r3vlimited.com/board/showthread.php?t=162444
          • Andrew325is
            • Jan 2008
            • 1209
            #155
            No, I gave up on it. It's too fun to rev the S54 anyways. :D
            • gills
              • Jan 2006
              • 275
              #156
              Which transmission crossmember did you use for the ZF 5 speed?
              • gills
                • Jan 2006
                • 275
                #157
                and, what intake tube is that you're running? (the silver piece)
                • Andrew325is
                  • Jan 2008
                  • 1209
                  #158
                  The original E30 crossmember.
                  K&N Typhoon 69-2001TS
                  • gills
                    • Jan 2006
                    • 275
                    #159
                    Thank you, sir!
                    Sent from my iPad using Tapatalk
                    • gills
                      • Jan 2006
                      • 275
                      #160
                      Also, what are limitations on Flywheel and clutch setups using the 5 speed?
                      The guy who sold me my S54 threw in a LTW flywheel and clutch kit that came out of a 2000 M Roadster with an S52 and 5 speed. It's a E34 M5 pressure plate and sprung hub clutch disc and the FW is a 8.5 lbs single mass aluminum unit. I'm still trying to find out what brand flywheel it is as it isn't UUC (not blue anodized) and UUC is the only company I can find that makes a FW that's 8.5lbs and is sold with an E34 clutch kit.
                      Can I use this setup with the S54 and ZF 5 speed?
                      • Wanganstyle
                        • 2828
                        #161
                        One can fit a M20 oem (or aftermarket) clutch and flywheel to a s54 and zf 5 speed.
                        All the bmw small 6 clutches can be interchanged (m20, m50, m54, s50, s54)
                        Sent from my SAMSUNG-SGH-I337 using Tapatalk
                          • 34835
                          #162
                          I think he's wondering if there are any bad effects to such a light flywheel on the S54.
                          personally I wouldn't want to run an 8.25lb flywheel on the street no matter what engine it was.
                          • Wanganstyle
                            • 2828
                            #163
                            S54 enjoys eating harmonic dampers........
                            S54 seems to eat the most dampers when on track racing with light race clutches and single mass fly (racing twin disc etc)
                            S54 only comes from bmw with a dual mass flywheel; this is calculated by the engineers in the harmonic balancer / damper design.
                            So the question is full raze then nothing will stop him from installing something full raze.
                            If one desires an oem type installation with longevity then a dual mass fly would be chosen.
                            Tons of reasonably lightweight dual mass setups;
                            M54b30 zhp / z4 3.0 20#/ s52 22#/ s54 30# dual mass and associated clutchset is not much heavier than a stock m20 single mass setup.
                            • gills
                              • Jan 2006
                              • 275
                              #164
                              Not wondering about bad effects of the LTW setup, as that is pretty common across the board.
                              I was wondering about what actually fits:
                              which is very helpful. Thank you, waganstyle!
                              • gills
                                • Jan 2006
                                • 275
                                #165
                                OT: I contacted Fidanza flywheels for help identifying the FW I have and it turns out it's a very rare one. They used to make it for Dinan/BMW and is very similar to the one they make for UUC's stage II setup. Funny thing is I called Dinan and asked if they ever made an aluminum FW for the E36 and the guy said no. Time to sell a Dinan FW! lol
